Народ помогите разобратся карта OrionExpress не могу ни как заставить работать
вот что пишет лог
09:17:47.313 wicardd: wicardd-mipsel version 1.18 neosheen (Aug 24 2014) http://wicard.tv
09:17:47.314 wicardd: Build options: [AutoConf] [TuxBox SCI] [DVBAPI] [WEBIF] [ExMLog] [TWIN]
09:17:47.321 dvb_filter: Wrong or unused config key 'filter = dvb_filter'
09:17:47.322 dvb_filter: Filter object created.
09:17:47.323 R0[tuxbox]: activity_timeout = 9000 ms
09:17:47.325 R0[tuxbox]: not decoded cache initialized, size: 64, ttl: 3000
09:17:47.328 wicardd: creating default balancer.
09:17:47.329 default: [balancer] chain key missed, creating default chain including all readers.
09:17:47.330 default: balancer object created, 1 stage(s).
09:17:47.338 R0[tuxbox]: reader thread started, pid 1122, tid 1998058656
09:17:47.355 DVB0[DVBAPI3]: starting camd.socket handler thread
09:17:47.356 DVB0[DVBAPI3]: DVB handler thread started, pid 1124, tid 1996047520
09:17:47.357 DVB0[DVBAPI3]: camd.socket listen() failed (9 Bad file descriptor)
09:17:47.358 DVB0[DVBAPI3]: cannot create /tmp/camd.socket
09:17:47.359 webif: server worker thread started, pid 1125, tid 1994998944
09:17:47.360 wicardd: registered 1 filter(s), 1 reader(s), 1 balancer(s), 0 tuner(s) and 0 server(s)
09:17:47.360 wicardd: loaded 0 user account(s)
09:17:47.361 wicardd: ECM cache size = 0
09:17:47.361 wicardd: main thread, pid 1120, tid 2000269312
09:17:47.376 wicardd: Discovery thread terminated.
09:17:47.839 R0[tuxbox]: Card inserted
09:17:47.840 R0[tuxbox]: card reset
09:17:48.037 R0[tuxbox]: T=0 fs=5 mhz ETU=64 WWT=9600 CWT=0 BWT=0 EGT=3 clock=0 check=0 P=0 I=0 U=0
09:17:48.038 R0[tuxbox]: card 3B
09:17:48.039 R0[tuxbox]: card 34
09:17:48.039 R0[tuxbox]: card 94
09:17:48.039 R0[tuxbox]: card 00
09:17:48.040 R0[tuxbox]: card 30
09:17:48.040 R0[tuxbox]: card 42
09:17:48.041 R0[tuxbox]: ATR: 3B 34 94 00 30 42 30 30
09:17:48.041 ATR: direct convention, Y1: 03, historical bytes: 4
09:17:48.041 ATR: TA1: 94, F=512, D=8
09:17:48.041 ATR: TB1: 00, II=25mA, PI1(Vpp)=0V
09:17:48.042 ATR: ATR len=8 (4 interface, 4 hist) 30 42 30 30
09:17:48.042 R0[tuxbox]: reader_init_cardreader OK
09:17:48.042 R0[tuxbox]: ATR 3: 3B 34 94 00 30 42 30 30
09:17:48.042 R0[tuxbox]: CAS is 0B00, ATR len 8 3B 34 94 00 30 42 30 30
09:17:48.044 R0[tuxbox]: CAM DD 26 00 00 03
09:17:48.044 R0[tuxbox]: card E0
09:17:48.045 R0[tuxbox]: CAM 10 01 40
09:17:48.046 R0[tuxbox]: card E0
09:17:49.412 R0[tuxbox]: Cannot initialize Conax card, SW = 0000, ret = -1
09:17:49.913 R0[tuxbox]: Card inserted
09:17:49.914 R0[tuxbox]: card reset
09:17:50.111 R0[tuxbox]: T=0 fs=5 mhz ETU=64 WWT=9600 CWT=0 BWT=0 EGT=3 clock=0 check=0 P=0 I=0 U=0
09:17:50.112 R0[tuxbox]: card 3B
09:17:50.112 R0[tuxbox]: card 34
09:17:50.112 R0[tuxbox]: card 94
09:17:50.112 R0[tuxbox]: card 00
09:17:50.113 R0[tuxbox]: card 30
09:17:50.113 R0[tuxbox]: card 42
09:17:50.114 R0[tuxbox]: card 30
09:17:50.114 R0[tuxbox]: ATR: 3B 34 94 00 30 42 30 30
09:17:50.114 ATR: direct convention, Y1: 03, historical bytes: 4
09:21:34.646 R0[tuxbox]: T=0 fs=5 mhz ETU=64 WWT=9600 CWT=0 BWT=0 EGT=3 clock=0 check=0 P=0 I=0 U=0
09:21:34.647 R0[tuxbox]: card 3B
09:21:34.647 R0[tuxbox]: card 34
09:21:34.647 R0[tuxbox]: card 94
09:21:34.648 R0[tuxbox]: card 00
09:21:34.648 R0[tuxbox]: card 30
09:21:34.648 R0[tuxbox]: card 42
09:21:34.649 R0[tuxbox]: card 30
09:21:34.649 R0[tuxbox]: ATR: 3B 34 94 00 30 42 30 30
09:21:34.649 ATR: direct convention, Y1: 03, historical bytes: 4
09:21:34.649 ATR: TA1: 94, F=512, D=8
09:21:34.649 ATR: TB1: 00, II=25mA, PI1(Vpp)=0V
09:21:34.650 ATR: ATR len=8 (4 interface, 4 hist) 30 42 30 30
09:21:34.650 R0[tuxbox]: reader_init_cardreader OK
09:21:34.650 R0[tuxbox]: ATR 3: 3B 34 94 00 30 42 30 30
09:21:34.650 R0[tuxbox]: CAS is 0B00, ATR len 8 3B 34 94 00 30 42 30 30
09:21:34.652 R0[tuxbox]: CAM DD 26 00 00 03
09:21:34.652 R0[tuxbox]: card E0
09:21:34.653 R0[tuxbox]: CAM 10 01 40
09:21:34.654 R0[tuxbox]: card E0
09:21:36.020 R0[tuxbox]: Cannot initialize Conax card, SW = 0000, ret = -1
09:21:36.521 R0[tuxbox]: Card inserted
09:21:36.522 R0[tuxbox]: card reset
09:21:36.719 R0[tuxbox]: T=0 fs=5 mhz ETU=64 WWT=9600 CWT=0 BWT=0 EGT=3 clock=0 check=0 P=0 I=0 U=0
09:21:36.720 R0[tuxbox]: card 3B
09:21:36.720 R0[tuxbox]: card 34
09:21:36.720 R0[tuxbox]: card 94
09:21:36.721 R0[tuxbox]: card 00
09:21:36.721 R0[tuxbox]: card 30
09:21:36.721 R0[tuxbox]: card 42
09:21:36.722 R0[tuxbox]: card 30
09:21:36.722 R0[tuxbox]: ATR: 3B 34 94 00 30 42 30 30
09:21:36.722 ATR: direct convention, Y1: 03, historical bytes: 4
09:21:36.723 ATR: TA1: 94, F=512, D=8
09:21:36.723 ATR: TB1: 00, II=25mA, PI1(Vpp)=0V
09:21:36.723 ATR: ATR len=8 (4 interface, 4 hist) 30 42 30 30
09:21:36.723 R0[tuxbox]: reader_init_cardreader OK
09:21:36.724 R0[tuxbox]: ATR 3: 3B 34 94 00 30 42 30 30
09:21:36.724 R0[tuxbox]: CAS is 0B00, ATR len 8 3B 34 94 00 30 42 30 30
09:21:36.725 R0[tuxbox]: CAM DD 26 00 00 03
09:21:36.726 R0[tuxbox]: card E0
09:21:36.727 R0[tuxbox]: CAM 10 01 40
09:21:36.728 R0[tuxbox]: card E0
вот мой конфиг
[global]
log = /tmp/wicardd.log
log_size = 500
active = 1
log_udp = 192.168.1.35:514
debug = 1
daemon = 0
[webif]
port = 8081
debug = 3
[dvb]
active = 1
type = DVBAPI3
filter = dvb_filter
debug = 1
auto_update = 1
ecm_info = 2
[reader]
active = 1
type = tuxbox
device = /dev/sci0 #включение кард-ридера sci0 - нижний, sci1 - верхний.
debug = 3
[filter]
filter = dvb_filter
active = 1
name = dvb_filter
rule = caid=0b00;chid=15;accept
rule = caid=0602;reject
rule = caid=0B00;ident=0;accept
rule = accept
debug = 1
#[reader]
#name = shura
#type = newcamd525
#account = login:passwd@server.net
#multiport = 4000,4002,4003,4004,4005,4007,4008,4010,4011,4012,4013,4014,4018,4019,4022
#debug = 3
#reconnect_delay = 10
#emm_cache = 1
#ecm_ttl = 5000
[reader]
active = 0
async_mode = 1
name = BISS
type = emubiss
file = /etc/tuxbox/config/SoftCam.Key
filter = dvb
debug = 1
