Автор Тема: Black Hole 1.6.5 Full Hdmi-Cec  (Прочитано 16708 раз)
Оффлайн prekon
  • -> Вы поблагодарили: 163
  • -> Вас поблагодарили: 212
« : 21 Сентябрь 2011, 09:00:12 »
Black Hole 1.6.5 Full Hdmi-Cec - XTREND ET9000 and ET5000
YOU MUST TO HAVE LATEST BOOTLOADER !!!
What is new in 1.6.5?
New Skin Beyounce 14 by Matrix 10
- Fixed GreenScreen on CrossEPG
- Initial relase for ET9000 - VFD ALSO WORKS OK !!!
- MEDIATOMB updated to ver. 0.12.1
- NTFS-3G updated to ver. 2011.4.12.
- OpenVPN updated to ver. 2.2.1
- VsFTPd updated to ver. 2.3.4
- Dropbear updated to ver. 0.53.1
The new Black Hole Hdmi-Cec driver allow you to command two devices (Tv and Vu+ box) with only ONE Remote control (Tv remote control)
Not all television are compatibile with this funcion, as for example Panasonic seems to be not yet compatible with Bh Hdmi-Cec.
But Bh Hdmi-Cec is tested and report working on all latest Samsung(Anynet+), Philips and and other Tv models like Sony Bravia KDL40EX402 series.
But we cannot test all tv recent models, so please help us reporting your tests too with your television model.
Instructions to connect the box to your Hdmi-Cec compatible Tv:
1) Enter in your Tv Menu Options and enable all the Hdmi-Cec options.
2) Enter in your Vu+ box Black Hole Hdmi-Cec Panel Setup (blue->blue->Black Hole Hdmi Cec: Configure in this screen the right Hdmi connection port and enable Bh Hdmi-Cec.
3) Click Save (red) button and your box will try to connect with your Tv.
All Done. If your Tv is compatible you can now control Tv and Box with Tv rc.
Warning: You have to select the specific port option if your box is connected to an ampli.
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.
The image MUST be installed in the flash.
Black Hole can not support images not installed in the flash.
This latest version of the Black Hole series has been entirely rewritten and improved in the code for maximum stability and performance.
Please note that of all images Black Hole now has the best epg system:
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Community members can then download it from our servers.
This feature provides other benefits such as:
Increase download speed of EPG
Download EPG from any channel
Schedule the download of EPG decoder even during standby
Users can customize the providers using Add / Remove function
Main functions of the buttons on the remote
OK button = Skin with simple information
OK button x 2 = Extra Info Skin
Blue button = Black Hole Blue Panel
Blue button and then Red button = Black Hole Epg Panel
Blue button and then Yellow button = System Monitor Panel
Blue button long press = Extensions
Yellow button = Time Shift
Green button = Black Hole Green Panel
Green button long press = Subservices
Green button and then Red button = Fast Plugin Setup
Green button x 2 = Fast Plugin
Button Red = Start Record
Addons
Green button and then Yellow button takes you to:-
Dedicated server for BlackHole addons
Download and install additional packages from the Black Hole server
Infobar / OSD
Analog Clock Gui
Channel orbital location
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, BER
Infobar picons
Characteristics of BlackHole Panels
Blue Panel
Extra Settings
Black Hole Cron Manager (Manage schedules)
OSD Settings (OSD configuration)
Devices Manager
Black Hole HDMI Cec
Manager Kernel Modules (Kernel module web browsertor)
Inadyn Settings (Configure Inadyn)
Swap File Settings (Configure File Swap)
Hard Disk Settings (Configure Hard Drive)
Black Hole Mount Wizard (Mount points)
OpenVPN Panel ( OpenVPN Panel)
Samba / CIFS Panel ( Samba Panel)
NFS Server Panel ( NFS server Panel)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
UPnP Client Djmount
UPnP Server Mediatomb
Info Panel
1 - Gui Setting (Gui configurations)
2 - Service Information (information system)
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Global settings (global settings EPG)
Setting Provider (ISP settings)
Green Panel
Fast Plugin Setup (Configure quick access to your favourite plugin)
Fast Plugin (Access your favourite plugin)
Addons (added)
Addons Download Manager (Manager for package downloading)
Installation manual packages (Manual installation of Black Hole packages)
Manual Install IPK packages (Manual installation of IPK packages)
Addons Uninstall Panel (Uninstalled packages)
Black Hole Statistics (See connections, top downloads and more)
Скачать здесь:  http://hotfile.com/dl/130288055/7fe1c39/BlackHole-1.6.5-et9000-20110920.rar
« Последнее редактирование: 29 Ноябрь 2011, 17:40:33 от ooolexa »
Оффлайн gavd
  • -> Вы поблагодарили: 377
  • -> Вас поблагодарили: 307
    • http://resivermd.ru/
« Ответ #1 : 23 Сентябрь 2011, 16:50:47 »
Жаль.  Неохота  сносить  егами   чтоб  посмотреть  новый  Black Hole ..... А  в  самом   Black Hole  нет  ли  возможности  устанавливать  другие  имиджи на  HDD ?
Оффлайн 2boom
  • -> Вы поблагодарили: 25
  • -> Вас поблагодарили: 170
« Ответ #2 : 23 Сентябрь 2011, 17:24:15 »
gavd, в самом деле в этой версии bh неработает монтирования hdd никаким образом))))
Оффлайн minoga
« Ответ #3 : 27 Октябрь 2011, 23:28:38 »
Изначально установил BH-1.4.3. всё работало нормально.Были заморочки с монтированием жёсткого диска и не русским табло. Сейчас поставил BH-1.6.5. табло пишет по русски, нашёл способ монтирования жёсткого диска.Картинка на SD стала получше,HD-отлично.
  • -> Вас поблагодарили: 14211
Имиджи Black Hole
« Ответ #4 : 28 Ноябрь 2011, 23:30:23 »
- Dropbear updated to ver. 0.53.1[/b]
« Последнее редактирование: 29 Ноябрь 2011, 18:16:04 от ooolexa »
Имиджи Black Hole
« Ответ #5 : 29 Ноябрь 2011, 09:42:50 »
ooolexa, это та самоделка которая была выложена на других сайтах еще в сентябре и от которой, как от черной кошки отмахивалась команда Black Hole не признавая ее своей? Или это что-то официальное, ну или хотя бы правленное (про самоделку писали что она несколько кривовата :o) смотреть посты выше.
Имиджи Black Hole
« Ответ #6 : 29 Ноябрь 2011, 10:29:18 »
Этот имидж ничего общего не имеет с Black Hole,я когда ставил с другого ресурса,он сделан под ет9000,загрузчик нужно менять,по оформлению тот же open pli
Имиджи Black Hole
« Ответ #7 : 29 Ноябрь 2011, 10:47:23 »
Тогда вопросы. С какого ресурса взят? Какие дрова стоят? Последние-это ниочем, это же не очередь в баню...  Вроде имджи Black Hole строились по другому и отличались от OpenPli
Имиджи Black Hole
« Ответ #8 : 29 Ноябрь 2011, 10:58:48 »
vasilich07, здесь брал http://www.satavto.by/forum/topic13105.html
Дело в том,что я скачал сегодняшний имидж,папка et9000 точно такая же,да и размер одинаковый,ставить не стал.
Плага по монтированию дисков нет.Может я ошибаюсь,ooolexa поправит.
Добавлено: 29 Ноябрь 2011, 11:13:48
Специально сейчас попробовал залить этот имидж,даже папку поменял на ет9x00,так и зависает на флешенге,в прошлый раз я ради спортивного интереса залил старый загрузчик,поставил Black Hole 1.6.5 и разочаровался.
« Последнее редактирование: 29 Ноябрь 2011, 11:13:48 от Harmon555 »
Имиджи Black Hole
« Ответ #9 : 29 Ноябрь 2011, 12:48:22 »
Самый динамично развивающийся на данный момент это PLI.
Соответственно и имиджи на его основе.
Эта "черная дыра" для VU+ пишет имиджи, но как показывает опрос пользователей этих ресиверов, он даже не занимает первое место среди наиболее часто используемых.
Нового ядра нет ни на одном другом имидже, ни под один другой ресивер кроме ЕТ (на сегодняшний день) и только на имиджах PLI и имиджах на их основе.
Имиджи Black Hole
« Ответ #10 : 29 Ноябрь 2011, 15:14:03 »
Значит это и есть та самая самоделка и не стоит ее ставить с ее косяками, вот только не понятно для чего ее сейчас сюда залили >:(
« Ответ #11 : 29 Ноябрь 2011, 17:49:25 »
Извиняюсь увидел более новую версию и думал что официальное обновление от Black Hole , брал на satstation.co.uk этом ресурсе , если фуфел сейчас потрем и больше заливать данный имидж не будем.
