Автор Тема: Описание процессора Xtrend ET9000 (на английском)  (Прочитано 10726 раз)
  • -> Вас поблагодарили: 14210
MULTI-FORMAT HD DIGITAL VIDEO/AUDIO SOC FOR SATELLITE, IP, AND CABLE DVR SET-TOP BOX, WITH WATCH-AND-RECORD DVR
FEATURES
FEATURES (CONT.)
•   Advanced multi-format decoder supporting the following:
•   HD/SD H.264/AVC Main and High Profile to Level 4.1 (HD), Level 3.1 (SD)
•   VC-1 Advanced Profile @ Level 3, Simple and Main Profile
•   HD/SD MPEG-2 Main Profile at Main and High levels
•   MPEG still image decode
•   SD MPEG-4 P2 SP/ASP, DivX 3.11/4.11/5.x
•   Advanced audio processor supporting the following:
•   AAC LC, AAC LC+SBR Level 2, AAC+ Level 2, AAC-HE
•   Dolby® Digital, Dolby Digital Plus
•   MPEG I layers 1, 2, and 3 (MP3)
•   Windows Media®and Windows Media Pro audio
•   One pair of on-chip stereo high-fidelity audio DACs
•   3D SRS audio support
•   One I2S input port and one I2S output port, plus S/PDIF output
•   High-performance 2D-effects graphic engine
•   Studio-quality text and graphics at HD resolution
•   Supports multiple layers and windows
•   Digital noise and contour reduction (DNR/DCR)
•   Reduces artifacts such as block/mosquito noise
•   Picture-in-picture
•   Supports simultaneous HD+SD display
•   Mosaic Mode
•   Supports up to 16 video decode/display for video-rich navigation
•   Motion-adaptive deinterlacer with reverse 3:2/2:2 pulldown
•   OpenCable™ ready with on-chip MPOD support
•   400-MHz Dual-Core CMT MIPS32®/16e class processor
•   64-bit DDR2 DRAM controller
•   Dual SATA-2 interfaces for DVR and DVD applications
•   HD analog video encoder with simultaneous SD outputs
•   NTSC-M/J, PAL-BDGHIN/M/Nc, SECAM analog outputs
•   480i/480p/576i/576p/720p/1080i output formats
•   Component RGB/YPrPb HD/HD-DVO outputs
•   Macrovision® 7.1/NICAM support
•   SCART 1 and 2
•   Component, S-Video, and composite via six on-chip V-DACs
•   VBI encoders for CC/TTX with NABTS/CGMSA/WSS/ Gemstar®, AMOL I/II standards and dedicated TTX sideband
•   RF modulator with BTSC encoder
•   ITU-R-656 input and output ports
•   HDMI 1.3/DVI 1.0 Mac and PHY with HDCP 1.1
•   Broadcom security processor
•   AES/1DES/3DES/CSS/CPRM/DTCP copy protection
•   MPEG-2/DIRECTV/DVB/ARIB data transport demux with 1DES/3DES/DVB/Multi2/AES descramblers
•   V.92-capable soft modem with integrated SiLab Si305x system side device
•   Dual USB 2.0 host controller with host transceiver
•   Additional client USB 2.0 host controller/transceiver
•   Dual Ethernet MACs with integrated single PHY and MII
•   UHF remote control receiver
•   Dual Smartcard support
The BCM7405 is a high-performance, high definition (HD) satellite, cable, and IP set-top box DVR System-on-Chip solution. It combines a fast 1000-DMIPS MIPS32/MIPS16e™-class CPU, high-speed graphics processing, including video scaling and motion adaptive deinterlacing, a very flexible data transport processor, an MPEG-4/VC-1/MPEG-2-compliant video decoder, a programmable audio decoder, six video DACs, stereo high-fidelity audio DACs, dual Fast Ethernet ports, one with integrated PHY, triple USB 2.0, a PCI 2.3/Expansion Bus, a highspeed 400-Mhz DDR2 memory controller, and a peripheral control unit that provides a variety of set-top box control functions. Integrated in 65-nm technology, it offers one of the highest levels of single-chip system performance available for STB applications.
The MPEG-2 DVB-compliant transport stream/PES parser and demultiplexer is capable of simultaneously processing 256 PIDs via 128 PID channels in up to six independent external transport stream inputs and two internal playback channels. All 128 PID channels can be used by the record, audio, and video interface engine (RAVE), PCR processing, message filter, and output via the high-speed transport or remux module. The data transport module can be configured to support eight record channels for PVR functionality and six A/V channels to interface to audio and video decoders.
The transport provides 1DES/3DES/DVB/Multi2/AES descrambling support. A memory-to-memory DMA security module may be programmed for AES/1DES/3DES/CSS/CPRM/CPPM/DTCP copy protection algorithms/standards. The BCM7405 features the Broadcom
A new video decoder is featured in the BCM7405, which is capable of simultaneous decode of an HD and SD stream with picture-in-picture display. Other Mosaic or tiled stream combinations can also be supported for an enhanced video-rich navigation user experience. DivX 3.11/4.11/5.x and MPEG-4 Part 2 Simple Profile and Advanced Simple Profile at Level 5 are additionally supported.
The BCM7405 has an advanced audio processor capable of decoding a wide range of digital audio formats.This audio decoder also supports a number of popular transcoding operations such as AAC to DTS 5.1 or AC3+ to AC3.
BCM7405 video and graphics processing features significantly improved scaling and blending performance, enabling real-time videolike graphics effects to be implemented. Digital contour reduction improves the video quality of low bit-rate AVC video. An ITU-R-656 output port is also provided with teletext sideband.
The 1000-DMIPS MIPS32™ CPU has been designed to maximize overall system performance and has significantly improved cache performance over previous generation devices. The CPU subsystem also includes a Floating Point Unit.
Integrated peripherals include three UARTS, dual ISO7816 Smartcard interfaces, counter/timers, GPIO ports, a LED/keypad controller, IR receivers, an IR blaster, a UHF remote control receiver, an integrated soft modem system side device, and serial controllers.
BCM7405 Block Diagram
Secure Processor (BSP), providing secure key generation, management, and protection. The BSP also supports downloadable security
Broadcom®, the pulse logo, Connecting everything®, and the Connecting everything logo are among
the trademarks of Broadcom Corporation and/or its affiliates in the United States, certain other countries and/or the EU. Any other trademarks or trade names mentioned are the property of their respective owners.
  • -> Вы поблагодарили: 794
  • -> Вас поблагодарили: 573
« Ответ #1 : 21 Август 2011, 17:24:13 »
(перевод гугл )
Различных форматов HD Цифровой видео / аудио SOC для спутникового, IP и кабельным DVR SET-TOP BOX, с часами-И-RECORD DVR
ОСОБЕННОСТИ
ОСОБЕННОСТИ (ПРОДОЛЖЕНИЕ)
• Расширенные многоформатный декодер поддерживает следующие:
• HD / SD H.264/AVC Основная и высокий профиль на уровне 4.1 (HD), Level 3.1 (SD)
• VC-1 Расширенный профиль @ Level 3, простой и Main Profile
• HD / SD MPEG-2 Main Profile на главные и высокий уровень
• MPEG еще декодирования изображений
• SD MPEG-4 P2 SP / ASP, DivX 3.11/4.11/5.x
• Расширенная аудио процессор и поддерживает следующие:
• AAC LC, AAC LC + SBR 2-го уровня, AAC + 2-го уровня, AAC-HE
• Dolby ® Digital, Dolby Digital Plus
• MPEG I слоев 1, 2 и 3 (MP3)
• Windows Media ® и Windows Media Pro аудио
• Одна пара на-чипе стерео высококачественный ЦАП аудио
• 3D SRS поддержка аудио
• Один порт I2S вход и один выход I2S порт, плюс S / PDIF выход
• Высокая производительность 2D-эффектов графический движок
• Студия-качество текста и графики в высоком разрешении
• Поддержка нескольких слоев и окна
• Цифровой шум и контур (DNR / DCR)
• Снижает артефакты, такие как блок / комаров шума
• Картинка в картинке
• Поддержка одновременной HD + SD дисплей
• Мозаика режим
• Поддержка до 16 декодирования видео / дисплей для видео-богатых навигации
• Motion-адаптивный деинтерлейс с обратным 3:2 / 2:2
• OpenCable ™ готова со встроенной поддержкой ОПМП
• 400-МГц двухъядерный CMT MIPS32 ® / 16e процессор класса
• 64-разрядный контроллер памяти DDR2 DRAM
• Два SATA-2 интерфейсы для DVR и DVD-приложений
• HD аналоговые видеокодер с поддержкой одновременной выходы SD
• NTSC-M / J, PAL-BDGHIN/M/Nc, SECAM аналоговыми выходами
• Форматы 480i/480p/576i/576p/720p/1080i выходной
• Компонент RGB / YPrPb HD / HD-ДВО выходы
• Macrovision ® 7.1/NICAM поддержки
• SCART 1 и 2
• компонентный, S-Video и композитный через шесть на-чипе V-ЦАП
• VBI кодеры для CC / ТТХ с NABTS / CGMSA / WSS / Gemstar ®, Amol I / II стандартов и посвятил ТТХ боковой полосой
• ВЧ модулятор с BTSC кодировщик
• МСЭ-R-656 входных и выходных портов
• HDMI 1.3/DVI 1,0 Mac и PHY с HDCP 1.1
• Broadcom безопасности процессор
• AES/1DES/3DES/CSS/CPRM/DTCP защиты от копирования
• MPEG-2/DIRECTV/DVB/ARIB передачи данных извлекать с 1DES/3DES/DVB/Multi2/AES дешифраторы
• V.92-совместимый программный модем со встроенным устройством SiLab Si305x стороны системы
• Два USB 2.0 хост-контроллера с принимающими трансивер
• Дополнительный клиент USB 2.0 хост-контроллер / трансивер
• Двойной Ethernet ПДК с интегрированным PHY одного и MII
• UHF приемник дистанционного управления
• Поддержка двух смарт-карт
BCM7405 является высокая производительность, высокое разрешение (HD), спутникового, кабельного и IP Set-Top DVR окне Система-на-кристалле решение. Она сочетает в себе быстрые 1000-DMIPS MIPS32/MIPS16e ™-класс процессора, высокоскоростной обработки графики, в том числе масштабирование видео и деинтерлейсинг движения адаптивным, очень гибкий передачи данных процессором, MPEG-4/VC-1/MPEG-2-compliant видео декодер, программируемый звуковой декодер, шесть видео ЦАП, стерео высококачественный ЦАП аудио, два порта Ethernet Быстро, один со встроенным PHY-, трех портов USB 2.0, PCI 2.3/Expansion Автобус, высокоскоростной 400-МГц контроллер памяти DDR2, а также периферических блок управления, который обеспечивает разнообразие сет-топ функции пульта управления. Интегрированные в 65-нм технологии, он предлагает один из самых высоких уровней однокристальных производительность системы доступны для приложений STB.
MPEG-2 DVB-совместимый транспортный поток / PES парсер и демультиплексор способно одновременно обрабатывать 256 PID, через 128 PID каналов до шести независимых внешних транспортных потоков входа и два внутренних каналов воспроизведения. Все 128 каналов ПИД-регулятора могут быть использованы записи, аудио и видео движок интерфейса (RAVE), ПЦР обработки, фильтр сообщений, а выход через высокоскоростной транспорт или ремультиплексирования модуля. Модуль передачи данных может быть настроен на поддержку восьми каналов для записи PVR функциональность и шесть аудио / видео каналов для взаимодействия с аудио и видео декодеров.
Транспорт обеспечивает 1DES/3DES/DVB/Multi2/AES дескремблирования поддержки. Память-память DMA Защитный модуль может быть запрограммирован для AES/1DES/3DES/CSS/CPRM/CPPM/DTCP защиты от копирования алгоритмы / стандартов. BCM7405 функций Broadcom
Новый декодер видео показан в BCM7405, который способен одновременно декодирование HD и SD поток с картинка-в-картинке просмотров. Другой поток Мозаика или черепичной комбинации могут быть также поддерживается для расширения видео-богатый опыт пользователей навигации. DivX 3.11/4.11/5.x и MPEG-4 Part 2 Simple Profile и Advanced Simple Profile на уровне 5 дополнительно поддерживается.
BCM7405 имеет продвинутый аудио процессор, способный декодирования широкого спектра цифровых аудио formats.This аудио декодер также поддерживает ряд популярных операции транскодирования, такие как AAC, чтобы DTS 5.1 или AC3 + для AC3.
BCM7405 видео и графики функций обработки значительно улучшить масштабирование и смешивания производительности, что позволяет в режиме реального времени videolike графические эффекты должны быть реализованы. Цифровой контур сокращение улучшает качество видео низким битрейтом видео AVC. МСЭ-R-656 выходной порт также предоставляется с телетекстом боковой полосой.
1000-DMIPS MIPS32 ™ процессора была разработана, чтобы максимизировать общую производительность системы и значительно улучшило производительность кэша по сравнению с предыдущими устройствами поколения. Процессор также включает в себя подсистемы плавающей точкой.
Встроенные периферийные устройства включают в себя три UART, двойной интерфейс смарт-карт ISO7816, счетчика / таймера, GPIO портов, LED / клавиатуры контроллера, ИК-приемники, ИК-бластер, управление удаленным UHF приемник, интегрированный программный модем со стороны системы устройства и серийный контроллеров.
BCM7405 Блок-схема
Безопасные процессор (BSP), обеспечивающие безопасное поколения ключ, управления и защиты. BSP также поддерживает загружаемые безопасности
Broadcom ®, пульс логотип, все Подключение ®, а также все Подключение логотип среди
товарными знаками компании Broadcom Corporation и / или ее филиалов в США, некоторых других странах и / или ЕС. Любые другие торговые марки или торговые наименования упомянутых, являются собственностью их соответствующих владельцев.
Оффлайн 2boom
  • -> Вы поблагодарили: 25
  • -> Вас поблагодарили: 170
« Ответ #2 : 21 Август 2011, 18:29:20 »
Уважаемые, давайте без гугл переводов, кому надо сам переведет через гугл, а так инфа всеравно не читаема, и это касается всех описаний, оригинал или немашинный перевод..... всем спасибо....
Оффлайн Макс
  • VIP
  • -> Вы поблагодарили: 150
  • -> Вас поблагодарили: 125
  • библиАтекарь
« Ответ #3 : 23 Август 2011, 21:51:09 »
Информация от производителя
ET9000 / ET5000 use chipset  BCM7405 dual core 1100DMIPS
    BMIPS 4380
     Dual MSIP32 (405MHz) and FPU Architecture
    1100 DMIPS
     I-Cache(32KB)
     D-Cache(64KB)
     8K RAC
     128K L2 Cache
§  ET9000 memory 512M
§  ET5000 memory 256M
