Автор Тема: bh 1.6.4 for et5k  (Прочитано 25949 раз)
Оффлайн 2boom
  • -> Вы поблагодарили: 25
  • -> Вас поблагодарили: 170
bh 1.6.4 for et5k
« : 06 Сентябрь 2011, 21:38:09 »
не могу проверить, но странная инфо владельцы et5k проверьте инфу
http://www.clarke-support.com/Forum/showthread.php?3214-NEW-BlackHole-ET-1.6.4-Full-HDMI-CEC-ET5000-!!!!!!
  • -> Вы поблагодарили: 3113
  • -> Вас поблагодарили: 14231
bh 1.6.4 for et5k
« Ответ #1 : 06 Сентябрь 2011, 22:32:49 »
2boom, информация верная есть такой имидж.
Black Hole 1.6.4 Full Hdmi-Cec - XTREND ET5000
YOU MUST TO HAVE LATEST BOOTLOADER !!!
What is new ?
The new Black Hole Hdmi-Cec driver allow you to command two devices (Tv and Vu+ box) with only ONE Remote control (Tv remote control)
Not all television are compatibile with this funcion, as for example Panasonic seems to be not yet compatible with Bh Hdmi-Cec.
But Bh Hdmi-Cec is tested and report working on all latest Samsung(Anynet+), Philips and and other Tv models like Sony Bravia KDL40EX402 series.
But we cannot test all tv recent models, so please help us reporting your tests too with your television model.
Instructions to connect the box to your Hdmi-Cec compatible Tv:
1) Enter in your Tv Menu Options and enable all the Hdmi-Cec options.
2) Enter in your Vu+ box Black Hole Hdmi-Cec Panel Setup (blue->blue->Black Hole Hdmi Cec: Configure in this screen the right Hdmi connection port and enable Bh Hdmi-Cec.
3) Click Save (red) button and your box will try to connect with your Tv.
All Done. If your Tv is compatible you can now control Tv and Box with Tv rc.
Warning: You have to select the specific port option if your box is connected to an ampli.
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.
The image MUST be installed in the flash.
Black Hole can not support images not installed in the flash.
This latest version of the Black Hole series has been entirely rewritten and improved in the code for maximum stability and performance.
Please note that of all images Black Hole now has the best epg system:
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Community members can then download it from our servers.
This feature provides other benefits such as:
Increase download speed of EPG
Download EPG from any channel
Schedule the download of EPG decoder even during standby
Users can customize the providers using Add / Remove function
Main functions of the buttons on the remote
OK button = Skin with simple information
OK button x 2 = Extra Info Skin
Blue button = Black Hole Blue Panel
Blue button and then Red button = Black Hole Epg Panel
Blue button and then Yellow button = System Monitor Panel
Blue button long press = Extensions
Yellow button = Time Shift
Green button = Black Hole Green Panel
Green button long press = Subservices
Green button and then Red button = Fast Plugin Setup
Green button x 2 = Fast Plugin
Button Red = Start Record
Addons
Green button and then Yellow button takes you to:-
Dedicated server for BlackHole addons
Download and install additional packages from the Black Hole server
Infobar / OSD
Analog Clock Gui
Channel orbital location
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, BER
Infobar picons
Characteristics of BlackHole Panels
Blue Panel
Extra Settings
Black Hole Cron Manager (Manage schedules)
OSD Settings (OSD configuration)
Devices Manager
Black Hole HDMI Cec
Manager Kernel Modules (Kernel module web browsertor)
Inadyn Settings (Configure Inadyn)
Swap File Settings (Configure File Swap)
Hard Disk Settings (Configure Hard Drive)
Black Hole Mount Wizard (Mount points)
OpenVPN Panel ( OpenVPN Panel)
Samba / CIFS Panel ( Samba Panel)
NFS Server Panel ( NFS server Panel)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
UPnP Client Djmount
UPnP Server Mediatomb
Info Panel
1 - Gui Setting (Gui configurations)
2 - Service Information (information system)
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Global settings (global settings EPG)
Setting Provider (ISP settings)
Green Panel
Fast Plugin Setup (Configure quick access to your favourite plugin)
Fast Plugin (Access your favourite plugin)
Addons (added)
Addons Download Manager (Manager for package downloading)
Installation manual packages (Manual installation of Black Hole packages)
Manual Install IPK packages (Manual installation of IPK packages)
Addons Uninstall Panel (Uninstalled packages)
Black Hole Statistics (See connections, top downloads and more)
Credits
Thanks to the group of Beta Testers.
Thanks to Rytec for providing us with the server with all epg.dat files.
Thanks to MaxZ4 for Integrated EPG loader.
Thanks to Sandro Cavazzoni for Cross EPG
Thanks to Lukkino (VDR-Italy) for the source code of OpenTV.
Thanks to Reinh@rd for the file satellites.xml.
Thanks to bigroma (vuplus-community board) for rt3070 patches.
скачать имидж Black Hole 1.6.4 Full Hdmi-Cec - XTREND ET5000
« Последнее редактирование: 06 Сентябрь 2011, 22:40:55 от ooolexa »
Оффлайн 2boom
bh 1.6.4 for et5k
« Ответ #2 : 06 Сентябрь 2011, 23:00:47 »
откуда инфа что это не фейк, много вопросов, выложен он был 3 часа назад, отзывов , кроме а где для et9k больше нет, почему только для 5000 странно все это... выглядит
bh 1.6.4 for et5k
« Ответ #3 : 06 Сентябрь 2011, 23:43:50 »
2boom, вот что отписали на форуме clarke-support  в теме где выложили данный имидж.
lorenzo64    :    Это не blackhole оригинальный имидж.blackhole команда к которой я принадлежу не делала этого имиджа кларк технологий
angelofsky1980     : Команда BH полностью игнорирует этот образ ET5000 и просит администраторов, чтобы удалить его с поля Кларк-поддержки.
Оффлайн Макс
  • -> Вы поблагодарили: 150
  • -> Вас поблагодарили: 125
  • библиАтекарь
bh 1.6.4 for et5k
« Ответ #4 : 07 Сентябрь 2011, 00:07:08 »
Прикольно, а я залил
Вроде пашет, но уже в зеленку на Cross EPG выпал...
Оффлайн Sirius0103
  • -> Вы поблагодарили: 147
  • -> Вас поблагодарили: 206
  • awards За благодарности Продвинутый пользователь За весомый программный вклад Творческая личность
bh 1.6.4 for et5k
« Ответ #5 : 07 Сентябрь 2011, 00:10:18 »
Крашлог можно посмотреть  :)
Оффлайн Макс
  • библиАтекарь
bh 1.6.4 for et5k
« Ответ #6 : 07 Сентябрь 2011, 00:15:18 »
Я смотрю кто-то не дождался имиджа от команды и решил взять инициативу в свои руки...  ;D
Оффлайн 2boom
bh 1.6.4 for et5k
« Ответ #7 : 07 Сентябрь 2011, 00:28:50 »
мне кажется запланированая утечка из бх и можно на et9k не ждать, после выхода оф имиджа на ву все даже самые ленивые выпустили новые имиджи, только bh проигнорировала сие действо и теперь многое становится понятно, видно производители ву задерживают денежку, а bh их взбадривает таким образом, сейчас им заплатят денжку и они со спокойной душой выпустят 1.6.5 а et оставят в покое на полгода....
Оффлайн 2boom
bh 1.6.4 for et5k
« Ответ #8 : 07 Сентябрь 2011, 08:16:57 »
на www.clarke-support.com уже убрали .....
http://www.vuplus-community.net/ написали следующее
It is not our orginal image
 is clone image that starts to look like the clone activities
 and that we do not support, nor we will support.
 I am warning you to remove the image
 before it's too late
 In this way you will not get any legal support for your box
 not now and not tomorrow.
Matrix10, Today at 12:41 AM
класс раньше были клоны ресиверов, теперь кним добавились клоны имиджей, прям Star Wars part II )))))))))))))
Оффлайн tolik501
  • Модель ресивера: et9000
bh 1.6.4 for et5k
« Ответ #9 : 07 Сентябрь 2011, 17:53:45 »
et9000-http://www.speedyshare.com/files/30212904/download/blackhole%201%206%204a%20et9000%20image%2020110907.rar
P.S.источник:http://www.et-support.com/forum/showthread.php?92-BlackHole-ET-1.6.4-Full-HDMI-CEC-!!!!!!
Оффлайн 2boom
bh 1.6.4 for et5k
« Ответ #10 : 07 Сентябрь 2011, 18:35:53 »
tolik501, но то что утечка, можно не сомневатся, или раскол в команде, на оф форуме, бвло написано то что цитировал, но клоны имиджей это интересно....
PS Наблюдал подобное около года назад , акурат помойму в сентябре когда раскололась команда dream elit, форум умер, но потом возродился под именем Black hole только для ву+... посмотрим интерсно дефки пляшут))))))))) оживлянчик какойто....
Оффлайн 2boom
bh 1.6.4 for et5k
« Ответ #11 : 07 Сентябрь 2011, 20:33:47 »
Поставил посмотрел, это порт с ву, делался явно не беховцами, впечатления отрицательные, винт как ни монтировал не увидел, дрова старые , картинка размытая, буквы на vfd скачуть, конечно перед людми кто портировал снимаю шляпу, молодцы как для первого раза хорошо, но неболее, поигрался и снес....
Оффлайн bigroma
  • -> Вы поблагодарили: 17
  • -> Вас поблагодарили: 86
  • awards V.I.P
  • Модель ресивера: dm500HD
bh 1.6.4 for et5k
« Ответ #12 : 08 Сентябрь 2011, 09:30:49 »
Навернео все таки не сами готовили, за один день в ВУ вопросы по денежке не решили бы:) openblackhole'ом пугали с месяц насколько помню. Ну и не верю я в имиджи не на базе ОпенПЛИ с новыми дровами в ближайшее время. Тем более что чую или вот вот пойдет новая энигма с более серъезной защитой от клонов и thirdparty моделей или вообще закроют свободны доступ к части сырцов и будут идти прекомпиленные либы к самым ответственным частям проекта.
Так что у себя дома я пока беру курс на ОпенПЛИ.
Оффлайн Vangard
bh 1.6.4 for et5k
« Ответ #13 : 28 Февраль 2014, 20:27:00 »
ребята а не появился ли случайно  к ресиверу ЕТ 5000 имидж компании Блек Холе 2.09?
bh 1.6.4 for et5k
« Ответ #14 : 28 Февраль 2014, 22:37:08 »
Нет, и не будет.
