Автор Тема: Clarke-Xtrend Support Image V3  (Прочитано 32975 раз)
Оффлайн prekon
  • -> Вы поблагодарили: 163
  • -> Вас поблагодарили: 212
« : 29 Октябрь 2011, 08:43:25 »
Clarke-Xtrend Support Image V3   http://hotfile.com/dl/133558964/b2fbacc/clarke-xtrend-et9x20111027133804_usb.zip.html
Clarke-Tech Enhancements for the completely modular Image
- Clarke-Xtrend HD Lava Skin with pig (picture in graphic) in many menus
- Clarke-Xtrend Bootlogos and Radio Logo
- Clarke-Xtrend Panel
Please see attached Screenshots for a short overview of all Parameters
 - Best Sysinfopanel (complete overview of systemparameters)
- HDMI-CEC Support via Plugin
- WLAN fixes and support for 80211b/g/n Ralink, Realtek, Carl based USB-Dongles (rt2800USB, rtl871x, AR9170)
- Running "broken" Shellscript (as Cronjobs) will work
- Acousticpatch (needs a HDD that supports acoustic parameter consult HDD manufacturer for this)
Highlights:
-Clarke-Xtrend Webbrowser HbbTV. This image fully supports the unique Webbrowser HbbTV for more info
see the readme or visit our forum.
-Daemon Manager. For information - a daemon is a computer program that runs in the background. The daemon requires a start/stop script - the script must be executable (chmod 755), placed in /etc/init.d and the name must start with "dmon."
Switch Mode You can choose the way you want the Main Menu to be displayed choose between "text, icon or scroll".
Please change it in Settings / System / Customize / mainmenu list option
- CT News Feed
Clarke-Xtrend FEED Contents :
- Driver
- Games
- picons
- Plugins
- Setting
- Skins
- systemPlugins
- Update
Plugins added
CT-Panel
AudioSync
CutListEditor
EPGImport
GlassSysUtil
GraphMultiEPG
MediaPlayer
MediaScanner
PicturePlayer
Tuxtxt
WebMedia
Backup-Suite
Specialised version of MultiQuickbutton for Clarke-Tech ET9000 can be downloaded from CT feed.
Code:
 1. Zurück <: Zap History -
2. Vor >: Zap History +
3. Farbtasten
Rot:
Rot (lang):
Grün: Auswahl Optionskanäle
Grün (lang):
Gelb: Audio-Einstellungen
Gelb (lang):
Blau: Erweiterungsmenü
Blau (lang):
4. GUIDE: Programmübersicht
GUIDE (lang):
5. INFO (i): Programmübersicht
INFO (i) (lang):
6. MENU (Lang):
7. EXIT: Infobar
8. OK: Infobar
9. Steuerkreuz
Runter: Kanalliste
Links: Sender zur\'fcck -
Rechts: Sender vor +
Auf: Kanalliste
10. VOL. +/-: **
11. P+: Kanalliste
P-: Kanalliste
12. Filelist: Aufnahmen
Filelist (lang):
13. Playlist:
Playlist (lang):
14. zurückspulen << :
15. vorspulen >>:
16. Play/Pause >II: Starte Timeshift
17. REC: Aufnahmemenü
REC (lang):
18. Slowmotion I>: ***
19. Stop: Stoppe Timeshift
20. Timeshift: Starte Timeshift
Timeshift (lang): Stoppe Timeshift
21. search:
serach (lang):
22. Mark:
Mark (lang):
23. Timer:
Timer (lang):
24. Vkey: Aufnahmen
Vkey (lang):
25. PIP: Bild in Bild
PIP (lang): Tausche Bild in Bild
26. TEXT: Teletext
TEXT (lang):
27. subtitle: Untertitel
subtitle (lang): Untertitel-Einstellungen
28. AUDIO: Audio-Einstellungen
AUDIO (lang):
29. TV: TV
TV (lang):
30. Help (lang):
31. RADIO: Radio
RADIO (lang):
[/more]
Special thanks:
 pcd (Main Developer)
wallie2000 (Image-Support)
Clarkemaster(Skins,Bootlogos)
All Betatesters (Coolman, CoolST, icewaere, csm, dispatcher, tam2010, z-pg-3, Biki3, janosch )
mogli123 (MQB).
Pedro_newbie (image backup plugin)
Pli team (for the image background code)
All the other code developers and plugin developers
a big thanks to ClarkeBoss
« Последнее редактирование: 08 Ноябрь 2011, 12:22:47 от undergiven »
« Ответ #1 : 29 Октябрь 2011, 15:54:25 »
Кто нибудь пробовал этот имидж? Он заточен под linux 3.0 ???
Я тестировал Clarke-Tech Support Image V2,но там были траблы с кириллицей,а так имидж очень даже ничего.
Добавлено: 29 Октябрь 2011, 18:32:45
Шрифт кириллицы нормальный,тормозов нет.Хороший имидж.
« Последнее редактирование: 29 Октябрь 2011, 18:32:45 от Harmon555 »
Оффлайн 100s6
  • Модель ресивера: et9000
« Ответ #2 : 30 Октябрь 2011, 09:55:16 »
+100
Мне тож понравился  :) :) :)
Добавлено: 30 Октябрь 2011, 10:37:27
ставится поверх последней опенпли без заморочек...
Добавлено: 30 Октябрь 2011, 10:41:56
по моему лучшее из всего,что было до зтого!!!
« Последнее редактирование: 30 Октябрь 2011, 10:41:56 от 100s6 »
140Е-ALL-4.8E
Vantage7100+XtrendET9000
Оффлайн nikola
  • Модель ресивера: ET9000
« Ответ #3 : 31 Октябрь 2011, 17:53:50 »
Качество картинки  на этом имидже с теми же настройками, по сравнению с OpenPli 2.1 Linux3.0.3 beta Image World Exclusive дрянь мягко выражаясь.
« Ответ #4 : 31 Октябрь 2011, 18:59:00 »
Чем же будет картинка хуже на Clarke-Xtrend Support Image V3 ,ежели здесь тоже стоят дрова 3.0.3.... :-\
Добавлено: 31 Октябрь 2011, 19:22:16
Это как вечный спор - что лучше режим 1080i или 720p
720p конечно лучше, потому что это более разумный выбор: он лучше поддаётся MPEG-компрессии, исключает неоднозначный и неизбежно несущий потери процесс деинтерлейсинга, необходимый для отображения 1080i на ЖК-телевизорах, и наконец, он просто проще и логичнее. Чересстрочная развёртка, лежащая в основе формата 1080i, — это реликт эпохи электронно-лучевых трубок и аналогового телевидения, она не является эффективным способом компрессии цифрового сигнала.Вам кажется, что разрешение кадра 1080i составляет 1920 на 1080? Да, но только если оно не содержит никакого движения. Зоны, содержащие хоть какое-то движение, имеют разрешение вполовину меньшее — 1920x540. Да-да, 540!
« Последнее редактирование: 31 Октябрь 2011, 19:22:16 от Harmon555 »
Оффлайн nikola
« Ответ #5 : 31 Октябрь 2011, 19:44:32 »
Сравни.
Оффлайн gavd
  • -> Вы поблагодарили: 377
  • -> Вас поблагодарили: 307
    • http://resivermd.ru/
« Ответ #6 : 01 Ноябрь 2011, 16:24:33 »
Работает  ли  Barry   Allen  или  Meoboot  на  етом  имидже  и  есть  ли  они  в  репозитарии ?
Хочу  установить  мультибут  и  в  связи  с  етим  нужен  совет :   какой  лучше  выбрать  имидж  для  установки  во  флеш ?  Читал  что  для   мультибута  лучше  использовать  имидж  от  производителя  и  в  связи  с  етим  вопрос  Clarke-Xtrend Support Image V3  ето   имедж  от  производителя ?
« Ответ #7 : 01 Ноябрь 2011, 16:49:59 »
Бэкап разворачивается с флешки за несколько минут.
Этот имидж собран на основе ПЛИ, так что можно считать официальным.
За мультизагрузку. Есть на Егами, но там только старые имиджи грузит, так как новые драйвера Егами не понимает.
Для попробовать разные имиджи, лучше пользоваться бэкапом, потом новый имидж во флешь, не понравилось - восстановить с бэкапа тот, что больше всего нравилось.
имхо.
« Ответ #8 : 01 Ноябрь 2011, 18:40:48 »
Лучше скажите - где взять  Lava Skin ver.1  для этого имиджа?
Оффлайн 100s6
« Ответ #9 : 07 Ноябрь 2011, 18:55:23 »
Сравни.
пробовал и сравнивал!!! ничем не хуже...насыщенность цвета просто меньше
И в чём дрянь?
На фкус и цвет фломастеры разные..так часть говорят
140Е-ALL-4.8E
Оффлайн prekon
« Ответ #10 : 07 Ноябрь 2011, 21:33:15 »
А мне очень интересно про "Качество Цвета".
1.Каким образом или приборами Вы измеряли?
2. Какой у Вас ТВ?
3. Как подключен по скарту, HDMI, или тюльпанами?
Это имеет большое значение.
Оффлайн nikola
« Ответ #11 : 07 Ноябрь 2011, 22:26:44 »
Ты прав!
На фкус и цвет фломастеры разные..так часто говорят.
Полностью с тобой согласен.
Зачем спориш тогда?
Добавлено: 07 Ноябрь 2011, 22:49:55
2. Какой у Вас ТВ?
Если меня спрашиваешь:
1. Глаза.
2. Pioneer PDP-436FDE
3. HDMI(в установках на ресивере 1080i, avtorezolution включён)
Лично я сравнивал качество SD каналов.
« Последнее редактирование: 07 Ноябрь 2011, 22:49:55 от nikola »
  • -> Вы поблагодарили: 794
  • -> Вас поблагодарили: 573
« Ответ #12 : 08 Ноябрь 2011, 07:14:28 »
1. Глаза. 2. Pioneer PDP-436FDE3. HDMI(в установках на ресивере 1080i, avtorezolution включён)Лично я сравнивал качество SD каналов.
1. Глаза- у каждого человека восприятие цвета разное так что это вечный спор
2. Pioneer PDP-436FDE3-Изображение Pioneer PDP-436FDE
 Контрастность: 4000 : 1.
 Разрешение Pioneer PDP-436FDE: 1280 x 768.
 Яркость: 1100 кд/м2.
 Формат: 16:9.
и зачем так спорить?
Оффлайн nikola
« Ответ #13 : 08 Ноябрь 2011, 10:40:44 »
Вот только не надо умничать!
Нашёл главные показатели для плазмы.
« Ответ #14 : 08 Ноябрь 2011, 11:04:15 »
А почему именно 1080i,а не 720p ?
prekon,мне понравилась твоя реплика (Каким образом или приборами Вы измеряли?)
Изменение качества картинки можно увидеть только при использовании качественных виртуальных игр.
Чтобы хоть как-то определить качество картинки нужен спектрофотометр,а не человеческий глаз.
Тем паче сравнивать онлайн трансляцию передач как-то выглядит некорректно,они идут все с разным качеством и уровнем разрешения.
Я вот до сих пор не могу найти точные настройки для своего телевизора LG47LD750 в интернете,а вы о какой-то визуализации...
И ещё -
Для определения точности цветопередачи вводится понятие идеального монитора, которому соответствует цветовой охват Adobe RGB (1998). Поскольку профайлу Adobe RGB (1998) соответствует цветовая температура точки белого 6500 К (D65), то сопоставление цветовых охватов идеального и тестируемого мониторов корректно.
Под точностью цветопередачи понимается цветовая разница Delta E между цветом на идеальном мониторе и цветом на тестируемом мониторе, усредненная по множеству измеряемых цветовых полей.
В качестве шаблона измеряемых цветовых полей используется шаблон Monitor Testchart.txt, который прилагается к программе Eye-One Match 3.0.6 и применяется для создания профайла монитора.
Далее профайл сравнивается с результатами измерений монитора в центральной точке экрана и с файлом AdobeRGB. Для сравнения используется программа ProfileMaker Pro 5.0.5, в которой запускается утилита MeasureTool 5.0 (инструмент Comparing).
После этого сравниваются результаты измерения в цветовых координатах Lab для каждого цветового поля, а также расчет усредненного значения Delta E по всем цветовым полям.
Чем меньше усредненное значение Delta E, тем точнее цветопередача у тестируемого монитора.
