Автор Тема: Bootloader Xtrend ET9000 HD Twin  (Прочитано 8601 раз)
Оффлайн Threepm
  • Модель ресивера: Vu+ Solo
« : 11 Январь 2012, 18:24:34 »
How to Install ET9000 bootloader
1. Unzip the ET9000 folder in to the root directory of a USB Pen Drive.
2. Power off Receiver with switch on the back.
3. Insert USB Pen Drive into the USB socket .
4. Power on Receiver.
5. Update message will appear on the front display.
6. Press the OK button behind the front flap.
7. Bootloader will now install from the USB Pen Drive .
8. Receiver will reboot once the install is complete.
Bootloader is now installed.
Remove the USB Stick.
Very Important!!!.
Delete the folder after you've done the update.
If you use the same USB Stick to update your firmware and leave the cfe.bin file in the ET9000 folder by accident it could cause problems next time you try to update an image.
Latest bootloader you can download here.
« Последнее редактирование: 11 Январь 2012, 18:26:19 от PraetorianES »
