Автор Тема: New VIX Image ET 9x00 Series Version 2.4  (Прочитано 12814 раз)
« : 15 Май 2012, 23:24:01 »
15/05/2012 - Open ViX 2.4.96
http://www.world-of-satellite.com/
From VIX Team
Enigma: 04-05-2012.
Enigma Plugins: 04-05-2012.
GCC Version: 4.4.4
Vu + Kernel Version: 3.2.2
Vu+ Drivers: 2012-03-23
        If you have not already done so you will need to flash the latest bootloader
All Users
A full flash is required for this version of ViX image. Because of extensive changes you will not be able to perform an online update or restore any settings/plugin backups
New Features
Blindscan
Now uses RF values in GUI not IF.
 C band searches possible.
 Supports symbol rates from 1 - 45MHz.
Channel Selection
Support added to change font sizes and number of rows.
 Support added to have a 3rd event showing (skin dependent)
 Support added to display start time and end time for all events shown.
EPG Selection
 Added help screen to all epg selection screens.
 Added support to change font sizes and number of rows.
Language Selection
 Added English (UK) to available languages.
Translations
 Added support for English (UK).
Sorting
 You may now sort Menus, Settings and Plugin Browser alphabetically.
Network Browser
 Uses less memory during Scan.
 Moved to new Setup Mounts screen.
Openwebif
New style webif now accessed using default port 80
 Old style webif still available if required for use with certain PC signal meters and Fancontrol 2
About Screen
Added network info.
Plugins
As partof streamlining the image, removed NFS, AFP, Samba, OpenVPN, Inadyn, MiniDLNA & uShare from default image (still available to install through feeds)
Bootlogo's
 Now available for direct install via plugins feed.
On Screen Hints
Now available as options are selected.
USB DVB
Added dvb-as102 support (by Gennart1).
Skin
Brand New skin ViXBMC by markus625 added to feeds.
Native skins updated and optimised.
Instant Record from channel list, EPG or current channel.
Enhanced Movie List Features
Latest Drivers (23/3/2012).
Loads of under the hood changes made for a smoother user experience.
Button Mappings
Short Red** & *** - Show current channel EPG info (ViX Single EPG).
Long Red*** - HBBTV ( ET series and select channels only).
Short Green** & *** - Timers.
Long Green*** - AutoTimer Timers.
Short Yellow*** - EPG Search.
Long Yellow*** - Instant IMDB Database search on the current programme.
Short Blue - Extensions.
Long Blue*** - Plugins Menu.
EPG - Opens ViX EPG.
Left/Right** - Opens ViX QuickEPG.
Up/Down** - Open Full Screen Channel List.
TV Button** - Open Full Screen Channel List.
Long TV Button - Open Bouquets List.
** Can be changed in ViX Menu
*** Can be turned off in ViX Menu
Special Thanks
rytec - for his continued support.
zoka.cc for his Picon sets
All developers for their plugins used in the feeds of this image.
All of the ViX Beta team for their hours of testing and dedication on getting this image working.
Rob van der Does, belierzz, rimas, Henkka, raivo, eesatfan, Zartmy, Trial & june8 for their translation work.
Silverfox0786 for channel settings, picons and bootlogo's.
Huevos for his work on blindscan
Gennart1 for dvb-as102 support
Markus625 for skin ViXBMC
Note: Not all 3rd party plugins have been tested or are guaranteed to be compatable.
Requests
If anyone is interested in doing any translation work for the plugins and the image itself, please contact either Andy or Sicilian
СКАЧАТЬ ИМИДЖ
« Последнее редактирование: 15 Май 2012, 23:56:19 от Ednaz »
« Ответ #1 : 21 Май 2012, 22:32:57 »
Сегодня два раза ставил этот имидж,при полной перезагрузке зависает на ЕТ9x00 как в ступоре.
Обновил до ядра 3.3.0  такая же петрушка как на пли,с внешним диском крутится на спиннере..
GM версия была лучше.
« Последнее редактирование: 21 Май 2012, 22:36:58 от Harmon »
« Ответ #2 : 21 Май 2012, 22:43:33 »
У меня небыло проблем с этим имиджем. После полной перезагрузки все грузилось нормально.
« Ответ #3 : 22 Май 2012, 06:33:03 »
Harmon, подтверждаю все ставится очень ровно. Попробуй скачать и установить заново. Только качай ту версию, что в 1 посте темы и не обновляйся онлайн потому, что следующие обновления будут с линухом 3.3, а первая 3.2 (насколько помню для тебя это важно) :)
Я на данный момент установил довел до хорошего состояния (для себя покрайней мере) и сделал бекапы почти всех имиджей команд пишущих для ЕТ:
Openpli (3.2.2, 3.3.0 и их пропатченные бекапы на обоих ядрах);
Open AAF от 13.05;
VIX Image ET 9x00 Series Version 2.4;
ET9x00 HDF Teamimage v4.9.2;
ItalySat 2.0 Dragon Edition svn 038;
SifTeam Enigma2 Koala Xtrend Et9x00;
XTR v1.0 Experimental
Все ставятся и работают как надо :)
Осталось опробовать podhd-2.1-et9000, вчера ставил но не смог зайти по фтп и телнету, не догадался, что пароль у них по названию их сайта (спасибо georg подсказал)
Так что дерзай и все получится :D
« Последнее редактирование: 22 Май 2012, 07:08:05 от vasilich07 »
« Ответ #4 : 22 Май 2012, 07:35:51 »
vasilich07,
Попробую ещё раз,стало лень экспериментировать,ты случайно  не пробовал скин ET Media HD v3.7 ?
Не хватает конвертеров,а где взять? :-\
« Ответ #5 : 22 Май 2012, 07:52:43 »
Автор предупреждает, что на VIX этот скин не идет. Я его тестил и с CoolST списывался по этому поводу, он пробовал править но ничего не вышло... :(
« Ответ #6 : 22 Май 2012, 08:08:17 »
Слушай,в этой версии убрали настройку пульта? Что-то не нахожу в меню.
Кстати,родные VIX-совские скины хорошие.можно парочку  любимых подкинуть и всё.
« Последнее редактирование: 22 Май 2012, 08:10:29 от Harmon »
« Ответ #7 : 22 Май 2012, 08:31:27 »
Про пульт уже не помню, т.к. за последние вечера перебрал кучу имиджей, а по поводу скинов я так и делаю оставляю родные плюс до 5 любимых и проверенных (работающих на 100 процентов). На некоторых больше, на некоторых меньше например HDF так напичкан изначально (правда в основном плагинами что и ставить некуда)
« Ответ #8 : 22 Май 2012, 08:49:29 »
Вот он и глюк вчерашний ,ставлю плагин dvboptions 0.4 и всё,зависает на перезагрузке
Может кто подскажет - умышлено убрали эту опцию ?
И ещё ,подскажите как делать перевод меню, помню там нужен редактор...может займусь,у меня время есть.
« Последнее редактирование: 22 Май 2012, 08:52:35 от Harmon »
« Ответ #9 : 22 Май 2012, 11:34:28 »
Harmon, перевод делается с помощью программы Poedit какая там последняя версия не помню. Инструкцию по пользованию если погуглить тоже найти можно. А желание твое только приветствуется :)
« Ответ #10 : 23 Май 2012, 16:28:34 »
Жаль убрали dvboptions,а так имидж очень интересный,в версии 2.3 плагин этот был.
Привык к быстрому перемещению курсора.
Плагин никак не ставится,может кто нибудь подскажет как поправить положение?
« Ответ #11 : 05 Июнь 2012, 21:35:30 »
Подскажите ,есть  ли плагин Seekbar для VIX ?
У меня есть папка с  этим плагином с open pli,но он никак не хочет работать
И ещё,обновил имидж до версии 3.3.0,теперь не работает значок сеть,раньше я помню светился зелёненьким.
На ядре 3.2.2 значок мигает.....
В общем,на 3.3.0 не работает
Если кто хочет установить Seekbar,прикрепляю архив (Напомню этот плагин для быстрой перемотки в movieплеере)
Установить по FTP usr/lib/enigma2/python/Plugins/Extensions
« Последнее редактирование: 05 Июнь 2012, 23:19:38 от Harmon »
