Автор Тема: WiCard 1.18 CAM  (Прочитано 402891 раз)
  • -> Вы поблагодарили: 2676
  • -> Вас поблагодарили: 3569
WiCard CAM PLI
« Ответ #105 : 31 Март 2013, 20:37:44 »
Славик, правильно, там должно быть прописано filter = dvb
Оффлайн Harmon
  • -> Вы поблагодарили: 1484
  • -> Вас поблагодарили: 2441
WiCard CAM PLI
« Ответ #106 : 31 Март 2013, 20:46:36 »
Вот мой конфиг
Эдик посмотри,правильно?
Эмуль работает нормально
Кстати ,emucworks кроме travel уже ничего не открывает :D
[global
syslog = 1
log_udp = 192.168.1.100
daemon = 0
debug = 1
[webif]
port = 8081
debug = 3
active = 1
[dvb]
active = 1
type = DVBAPI3
rerequest_not_decoded = 1
sdt    = 1
debug = 3
auto_update = 1
ecm_info = 2
[reader]
active = 1
type = emubiss
caid = 2600
file = /usr/keys/SoftCam.Key
ecm_queue_size = 8
[reader]
active = 1
type = emuvia
caid = 0500
ecm_queue_size = 8
[reader]
active = 1
type = emucworks
caid = 0D00
ecm_queue_size = 8
[reader]
name = 3k
type = goldcard
fw_file = /etc/tuxbox/config/pic.hex
extee_file = /etc/tuxbox/config/ee.bin
auto_update = 1
debug = 0
[filter]
name = dvb
rule = caid=0D00,2600;accept
rule = caid=4ae1;ident=11;limit=1,10,0,0;accept=3k
rule = caid=0500;ident=040600,042700,023100,042300,043800,041700,042400,042800,040810;accept #NTV_SD all viaccess
rule = caid=0500;ident=050B00;sid=2f45,2f46,2f47,2f48,2f49,2f4a,3715,3716,3717,3718,3719,371A,4E85,4E86,4E87,4E88,4E89,4E8A,4E8B;accept #NTV_HD
rule = caid=0B0F;ident=0;accept #Xtra_TV
rule = caid=0652;chid=15;accept #Raduga
rule = caid=0602;ident=0;accept #Kontinent
rule = caid=090F;chid=15;accept #Viasat
rule = caid=0500;ident=023100;accept #TRK TRK Ukraina,Football,Futbol Plus
#rule = caid=4ae1;ident=0,11;ident:=0;accept #Tricolor
rule = caid=09CD;ident=0;accept #Sky_Italia
rule = caid=0654;ident=0,1;accept #Poverhnost+
rule = caid=0100;ident=000068;accept #Сyfra+
rule = caid=0BAA;ident=0;accept #Hello HD
rule = caid=0500;ident=023800;accept #SRG SSR + HD
rule = caid=0500;ident=042800;accept #BIS TV (13E)
rule = caid=0500;ident=042300;accept #RTVi(13E)
rule = caid=0500;ident=032500,042700,042200,041700,042200,043800;accept #ХХХ 13E
rule = caid=1803;ident=000000;accept #Cyfrowy Polsat
rule = reject
[reader]
active = 1
name = all
type = newcamd525
account = login:parol@server
multiport = port1,port2,port3,port4,port5,port6,port7,port8
reconnect_delay = 10
keepalive = 120
filter = dvb
[server]
active = 1
type = newcamd525
auto_provider = 3k
port = 10000
key = 0102030405060708091011121314
[account]
active = 1
login = card0
password = duo
auto_update = 1
« Последнее редактирование: 31 Март 2013, 20:55:24 от Harmon »
WiCard CAM PLI
« Ответ #107 : 31 Март 2013, 20:50:18 »
Славик, конфиг вполне правильный, только вот не пойму для чего активен у тебя последний reader
И у тебя сделано в фильтре так, что если нет для какого то провайдера идента и каллер ид прописанного в нем, то он отсекает все остальное. Если кто не знает что в фильтре нужно добавить, измените последнюю строку в фильтре rule = accept
« Последнее редактирование: 31 Март 2013, 20:54:22 от Ednaz »
Оффлайн Harmon
WiCard CAM PLI
« Ответ #108 : 31 Март 2013, 20:53:09 »
Ты прав ,он лишний.....удалил. ;D
Теперь легко,а то у меня портов тьма...
Пошёлкал каналы,вроде шустренько.
Спасиба ,irinka-1 !
« Последнее редактирование: 31 Март 2013, 21:01:40 от Harmon »
WiCard CAM PLI
« Ответ #109 : 31 Март 2013, 21:08:19 »
И поподробней об этом :  с балансным 3ко..с карты и шары[balancer]name = 3kkchain = 3k;all_port8mode = 2debug = 1
Славик, это для триколора добавлен балансировщик, до апдейта или при смене МК, будет получать ключи автоматом с сервера шары.
[balancer]
name = name #уникальное имя
name = default #в случае переопределения настроек для балансировщика, который используется поумолчанию
chain = 0,1;2;3 #цепочка ридеров задается имя ридера
 #chain = card_1, сard_2; card_3
 #что означает - запрос будет сбалансирован (по степени загрузки ридера) между двумя ридерами card_1 и card_2 и в случае,
 #если не будет декодирован, то будет передан в следующую по цепочке группу в которой только один ридер card_3
mode = 0 #0 - выбирать ридер с наименьшим временем декодирования запроса (кол-во запросов в очереди * среднее время декодирования)
 #1 - выбирать ридер с наименьшим кол-вом запросов в очереди
 #2 - выбирать первый ридер в группе
 #3 - round-robin
 # chain = cardA/3, сardB/5, cardC/123
 # через косую черту задается кол-во запросов, которые можно отдать в ридер, если порядковый номер поступившего запроса больше,
 # то запрос отправляется в следующий по цепочке ридер, если это последний ридер и кол-во запросов превышено,
 # обнуляются счетчики запросов всех ридеров и запрос передается в начало цепочки
 #4 - параллельное декодирование несколькими ридерами
debug = 3
« Последнее редактирование: 31 Март 2013, 21:25:59 от Ednaz »
Оффлайн irinka-1
  • -> Вы поблагодарили: 17
  • -> Вас поблагодарили: 20
  • awards Прекрасной половине нашего форума
  • Модель ресивера: 9200
WiCard CAM PLI
« Ответ #110 : 31 Март 2013, 21:12:08 »
Я не понял зачем filter = dre на multiport = port1,port2,port3,port4,port5,port6,port7,port8 ?
Не проще прописать dvb
[balancer]
name = 3kk
mode = 2
debug = 1
_______
закинул свой конфиг,прописал ш@ру в одну строчку,полёт нормальный,разницы в скорости не заметил
mgcamd 1.35а всё равно работает шустрее.ИМХО
по пунктам:
это балансная конфигурация..т.е. идет выбор откуда работать..
если проходит АУ по виртуальной карте-то смотрим 3к по ней..
если АУ не проходит-то идет переключение на порт8(3ко) по шаре..
как раз последний фильтр по dre -это в теории условие для 3к по шаре..
З.Ы. caid = 2600,caid = 0500,caid = 0D00 можно удалять..
я так понимаю-в этой версии эти строчки не нужны..
« Последнее редактирование: 31 Март 2013, 21:18:35 от irinka-1 »
Оффлайн Harmon
WiCard CAM PLI
« Ответ #111 : 31 Март 2013, 21:40:42 »
А зачем балансная конфигурация ? Если эумль ТИко шара у меня настроен на mgcamd-е
Да в принципе ,уже давно расшарили  каналы со сдвигом во времени,ждём HD 3k
Дело в том ,что WiCard  ещё нужно переписывать как кард сервер( вопрос обсуждался на гисклубе),потому как не все конвертеры  отображают его в скинах,тот же  дефолтный PLi
А так приходится переписывать сам конвертер в самом скине.
Тем паче, в mgcamd можно переключать сервера с кнопки.
« Последнее редактирование: 31 Март 2013, 21:47:51 от Harmon »
WiCard CAM PLI
« Ответ #112 : 31 Март 2013, 21:42:31 »
ждём HD 3k
Тут как бы вообще не накрыли шару  ;D
Оффлайн Harmon
WiCard CAM PLI
« Ответ #113 : 31 Март 2013, 21:50:40 »
На одном известном ш@раводе сказали что планируется,а там посмотрим. ;D
WiCard CAM PLI
« Ответ #114 : 31 Март 2013, 21:53:37 »
это будет огромная ЖО..!
  • -> Вы поблагодарили: 1239
  • -> Вас поблагодарили: 3617
WiCard CAM PLI
« Ответ #115 : 31 Март 2013, 22:21:04 »
Дружище,будем как-то выживать. :o
Оффлайн Alina007
  • -> Вы поблагодарили: 3272
  • -> Вас поблагодарили: 1137
  • Модель ресивера: et11000 4K
WiCard CAM PLI
« Ответ #116 : 03 Апрель 2013, 08:14:44 »
WiCard CAM PLI 1.12 перестал работать . Это у всех так или только у меня
WiCard CAM PLI
« Ответ #117 : 03 Апрель 2013, 08:17:50 »
Серега, имей совесть, включи ресивер в розетку!
WiCard CAM PLI
« Ответ #118 : 03 Апрель 2013, 08:20:02 »
Что именно не работает? Шара или трико эму?
Оффлайн Alina007
WiCard CAM PLI
« Ответ #119 : 03 Апрель 2013, 08:21:31 »
Эдик   шара не работает
