Автор Тема: Open AAF ET9X00 Release Image 01.05.2012  (Прочитано 14269 раз)
Оффлайн kladovchk
  • -> Вы поблагодарили: 92
  • -> Вас поблагодарили: 277
  • awards За заслуги перед wvclub.net За знание своего дела За верность клубу
« : 02 Май 2012, 21:35:51 »
Image 01.05.2012 Online
changes from 18.04 image:
- openpli Updates, big thx to openpli team for the great work
- openvix Updates, bix thx to Andy Black
- plugin filter (select show plugins in download manager, added kernel modules)
- add timeshift = enable/disable
- add Python camstarter setup (restart attempts)
- add startmode camdstarter (Python camstarter or linux init.d)
- add Software Manager in OpenAAF Panel (software update, backup settings, restore settings, select backup files)
- backup settings, add installed plugins list to backup file
- restore settings, add restart network, install plugins after restore
- fix USB-HDD when ussing hardwaretimer for standby
- fix radio button (showRadio)
- update default channel list (german HD channels)
- update webif (fix for softcam panel)
- fix cooleasytv skin
- fix cool uni tv skin
- fix permanenttimeshift and timeshift, works now also on the start channel
- update Webmedia7.0 on feed
- update aaf default picons for new german tv´s
- script create a swapfile (64Mb) on a USB stick for gb800xx, vusolo, et5000, dm800, dm800se, dm500hd (low mem)
Note to backup/restore settings:
Backup settings will create a file with installed plugins.
When the Software Manager notice this file after restore it will ask you if you want to install the missing plugins.
Only plugins that are not installed and they are installed on previous image, will be installed.
Ofcourse you can cancel or select the plugins to install.
After restore there will be a restart gui, like always (even if you cancel install plugins).
Note to swap file for for gb800xx, vusolo, et5000, dm800, dm800se, dm500hd:
Because of the low memory these boxes need a swapfile to run properly.
The swap file will be created the first time you boot.
Make sure you have a USB-stick FAT32 with at least 64Mb free space connected to a USB port.
Don't remove this stick while running !!
openaaf-1.0-et9x00-20120501_usb.zip
« Ответ #1 : 14 Май 2012, 07:14:44 »
Image 13.05.2012 Online
 Image Änderungen seit dem 01.05.2012
 - audioselection: fix close screen with key-audio or key-subtitle
 - aafpanel: fix save keymap selection
 - infobar: fix minutes
 - recordTimer: fix action after edit timer from instant record
 - infobargenerics: fix for Endtime and and Duration of the instand record
 - eventview: let info button in EventView close the window
 - networksetup: fix GS in FTP screen
 - harddisksetup: add show message after Initialization, Filesystem Check, Convert filesystem ext3 to ext4
Для меня важно, что поправили аудио АС3 :)
« Ответ #2 : 14 Май 2012, 07:28:08 »
vasilich07,
не поправили драйвера  для ntfs ?
« Ответ #3 : 14 Май 2012, 07:50:41 »
Нет :-\, тут все попрежнему. Выхода тут два, либо ждать от разработчиков новую версию линуха, над этим работа идет но результата нет пока...
Либо всем дружно попросить опен пли вернутся на 3.2.2 и развивать его. Но на этот щелчек по носу пли вряд ли пойдет ИМХО
« Ответ #4 : 14 Май 2012, 09:57:31 »
vasilich07, пытаюсь сделать онлайн обновление, но пишет, что нет файлов для обновления.
« Ответ #5 : 14 Май 2012, 10:05:37 »
Ednaz, проблема где то у тебя, т.к. я обновился помоему 89 пакетов. Мне еще не понятно, что у тебя и италисат не обновлялось, а у меня свободно...
« Ответ #6 : 14 Май 2012, 10:09:02 »
Вот в этом то и весь прикол, не обновляется, пишет сейчас один пакет для обновления и я его ставлю, потом пробую еще раз обновиться - снова пишет один пакет для установки. Включи скайп или аську.
« Ответ #7 : 14 Май 2012, 10:15:29 »
Эдик я на работе буду только после 16 МСК.
Попробуй качнуть с их сайта или отсюда
« Ответ #8 : 22 Май 2012, 12:43:01 »
Ни разу не ставил етот имедж,поставил  -эмуль работает,шарицца..... картинки нет ?
Что там ещё настраивать у буржуев надо?
Видно нужно настраивать как обведено на скринах зилёненькым,да?
« Последнее редактирование: 22 Май 2012, 12:46:11 от Harmon »
« Ответ #9 : 22 Май 2012, 12:50:14 »
В software menаger найди свой эмуль и перестартани
А почему не от 13 мая прошивку лил? Неушто такой суеверный? :)
« Последнее редактирование: 22 Май 2012, 12:56:50 от vasilich07 »
« Ответ #10 : 22 Май 2012, 12:53:03 »
Так и делал,видно же что шара работает,а вот картинки  и звука нет
Я правда не делал как на 4 -м скрине старт мод
« Ответ #11 : 22 Май 2012, 12:59:44 »
У меня все сразу пошло, установил эмули кинул свои настройки рестартанул эмуль и все ОК. Путь установки скрипта в четвертом скрине правильно указан
« Последнее редактирование: 22 Май 2012, 13:03:06 от vasilich07 »
« Ответ #12 : 22 Май 2012, 13:10:09 »
В общем снёс я его,вожусь с VIX
Я стразу сбросил на заводские настройки.
« Ответ #13 : 01 Июнь 2012, 07:12:12 »
Image 31.05.2012 Online
Image Änderungen seit dem 13.05.2012
 - install picons on usb-stick (format vfat)
 - fix GS in multiepg and don't zap back with exit
 - fix "zap+exit" multiepg
При актуализации с предыдущей версии необходимо добавить новый девайс менеджер:
Wer das aktuelle OpenAAF vom 31.05 installiert/aktualisiert muss, um Schreibzugriffe auf NTFS-formatierte Datenträger zu ermöglichen, zusätzlich noch ntfs-3g installieren.
 Die einfachste Möglichkeit dazu ist das Installieren der Geräteverwaltung , die benötigten zusätzlichen Pakete werden, sofern eine Internetverbindung besteht, automatisch nachinstalliert. Nach anschließendem Neustart funktionieren dann auch unter OpenAAF mit Kernel 3.3.0 wieder Schreibzugriffe auf NTFS.
Взять менеджер можно Здесь Нужна регистрация. Или возьмите в прицепе
Если устанавливаете вновь то скачать имидж можно Здесь Нужна регистрация
« Последнее редактирование: 01 Июнь 2012, 07:27:01 от vasilich07 »
« Ответ #14 : 20 Октябрь 2012, 19:46:28 »
openAAF Image mit Kernel 3.6.0 und Treiber 17.10.2012 Online
Вот и первая ласточка на новом кернеле и дровах
nach kurzer Pause geht es wieder weiter mit Images von openAAf Team
 Xtrend neue Kernel 3.6.0 mit neuen Treibern von 17.10 !!!!!
 was ist neu mit Kernel 3.6.0
 Kernel weiter Optimiert und Performance verbessert.
 neue WLAN Treiber und alte WLAN Treiber verbessert
 WEBCAM USB Kernel Module nun auf FEED
 div Bug fixe im EXT4 Modul
 Updates an den USB DVB Module
 und vieles mehr siehe auch Info auf http://www.heise.de/open/artikel/Die-Neuerungen-von-Linux-3-6-1714142.html
 Xtrend Treiber:
 neu Compiliert mir Aktuellen Broadcom SDK
 add HDMI-CEC Support ET4000
 fix 1080P mode und Scart bei ET4000
 optimiert vtuner support
 AAF:
 Update Softcam Manager
 Update Quickmenu
 Update aller Übersetzungen
 Update der Plugins auf feed
 Skin Fixe
 Updates div Linux Tools
 C***mInfo fix config path und Config Switcher
 Backup/Restore auch der lokal Installierten Plugins wenn sie auf USB/HDD liegen
 vor den restore müssen die extra Installieren Plugins unter /media/usb oder /media/hdd liegen
 div GS gefixt die gemeldet wurden beim Image 10.10
 alle changes findet ihr nun immer im Image unter Information -> Über Info Taste
 Images gibt es für alle Xtrend/CT Boxen
 ET4000, ET5000, ET6000, ET6500, ET9000, CT9000/9100, ET9200, ET9500
 Download gibt es hier:
Здесь
