На главной странице сайта найдете последние новости и обзоры
Blindscan function is added as an option in manual search:Menu -> Setup -> Service Searching -> Manual Scan -> Type of ScanChoice Blindscan
Круто!А как быстро он отрабатывает?
А в сателит.хмл добавляет транспондеры?Почему спрашиваю. Сейчас нет возможности самому проверить в связи с ремонтом квартиры, а плаг очень интересует и думаю не только меня и как он это все отрабатывает.
Changes: The blind scan frequently does not run to completion and suffers from other robustness issues, such as tuner hang after scan completion. The robustness is significantly improved. Both bands and polarisations can now be selected individually or together for the same run. No need to run the blind scan several times each for one band or polarisation. Frequency and symbol rate values are rounded to multiples of 1000.Comments:The blind scan is Ku band only.The binary executable is by ET and seems to work fine. It is fairly fast but occasionally misses transponders. Perhaps better results can be achieved by limiting the symbol rate range in the scan. Select one rate or a small range only. I have not tested this myself, though.There is a focusing stage in the beginning. This is necessary to achieve better robustness and in order not to loose transponders in the start of the scan. Please be patient.Once a blind scan has started you cannot interrupt it. You will need to wait until completion, which might take up to 5 minutes or so if both bands and polarisations are selected. As soon as the transponder scan is complete and the service scan starts you can press the ‘back’ or ‘esc’ button if you don’t want to continue. Nothing will be saved in that way.Rounding of frequency and symbol rates means that some 5 significant digits are available for each. More digits are technically insignificant and do not occur in technical publications.
Дима,по окончании сканирования,и по нажатию кнопки OK или EXIT,уходит в зелёнку.Если можно-поправь пожалуйста.
на их фиде есть вроде рабочая версия.
Эту версию не просто надо удалить,она еще и подменила какие то системные файлы,их теперь тоже менять надо.
opkg install enigma2-plugin-systemplugins-satscan
Системные плагины-->satscan
Этот есть.А слепого,Blind scan,поиска нет.
for tryname in ("avl_azbox_blindscan", "avl_xtrend_blindscan", "vuplus_blindscan"):
Это и есть слепой поиск.Я не вникал,но это должно быть продолжение Blind scan.
При установке Blind scan,в меню появлялась строка Слепой поиск.И когда его запускал,то он спрашивал на предмет поиска неизвестных транспондеров,и потом искал каналы.В satscan-немного по другому.Хотя врать не буду,может дальше и есть что-то похожее.Я запускал его,но не пробовал сканировать.
P.S.Плагин должен работать на ЕТ и ВУ+ ресиверах,по идеи на любом софте.Будут креш-логи,просьба выложить.
