Автор Тема: Эмулятор сервер-клиент Oscam-ymod  (Прочитано 222706 раз)
Оффлайн killer130
  • Модель ресивера: Xtrend ET-9000
Эмулятор сервер-клиент Oscam версия 1819
« Ответ #60 : 26 Февраль 2012, 02:48:04 »
killer130
Перекачайте данный файл, это файл libcrypto-compat_0.9.7-r2_all.ipk скачался с ошибкой и система не может открыть этот пакет.
Качал, то же самое :(
интересное - в установленных пакетах есть файл libcrypto-compat_0.9.8  :o
вот лог, может поможет
>> OSCam <<  cardserver started at Thu Jan  1 01:00:36 1970
1970/01/01 01:00:36        0 s starting thread log_list_thread
1970/01/01 01:00:36        0 s log_list_thread thread started
1970/01/01 01:00:36        0 s >> OSCam <<  cardserver started, version 1.20-unstable_svn, build #6450 (mipsel-tuxbox-linux)
1970/01/01 01:00:36        0 s version=1.20-unstable_svn, build #6450, system=mipsel-tuxbox-linux, nice=-1
1970/01/01 01:00:36        0 s client max. idle=9999999 sec, debug level=0
1970/01/01 01:00:36        0 s max. logsize=500 Kb, loghistorysize=4096 bytes
1970/01/01 01:00:36        0 s client timeout=8000 ms, fallback timeout=4000 ms, cache delay=0 ms
1970/01/01 01:00:36        0 s The current system time is smaller than the build date (Feb 25 2012). Waiting up to 60 seconds for time to correct
2012/02/26 01:29:40        0 s services reloaded: 0 services freed, 9 services loaded, rejected 0
2012/02/26 01:29:40        0 s userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
2012/02/26 01:29:40        0 s signal handling initialized (type=sysv)
2012/02/26 01:29:40        0 s 560 service-id's loaded in 22ms
2012/02/26 01:29:40        0 s oscam.tiers loading failed
2012/02/26 01:29:40        0 s 14 provid's loaded
2012/02/26 01:29:40        0 s 0 lengths for caid guessing loaded
2012/02/26 01:29:40        0 s can't open whitelist file /etc/tuxbox/config/oscam-experimental/oscam.whitelist
2012/02/26 01:29:40        0 s can't open cacheex-matcher file /etc/tuxbox/config/oscam-experimental/oscam.cacheex
2012/02/26 01:29:40        0 s Starting listener 0
2012/02/26 01:29:40        0 s monitor: initialized (fd=5, port=988)
2012/02/26 01:29:40        0 s camd35: disabled
2012/02/26 01:29:40        0 s cs378x: disabled
2012/02/26 01:29:40        0 s newcamd: initialized (fd=6, port=34000, crypted)
2012/02/26 01:29:40        0 s -> CAID: 4AE0 PROVID: 000015
2012/02/26 01:29:40        0 s pandora: disabled
2012/02/26 01:29:40        0 s csp: disabled
2012/02/26 01:29:40        0 s radegast: disabled
2012/02/26 01:29:40        0 s starting thread http
2012/02/26 01:29:40        0 s http thread started
2012/02/26 01:29:40        0 s starting thread reader check
2012/02/26 01:29:40        0 s reader check thread started
2012/02/26 01:29:40        0 s starting thread check
2012/02/26 01:29:40        0 s check thread started
2012/02/26 01:29:40        0 s creating thread for device /dev/sci0
2012/02/26 01:29:40        0 s loadbalancer: can't read from file /tmp/.oscam/stat
2012/02/26 01:29:40        0 s waiting for local card init
2012/02/26 01:29:40   57AFD0 h HTTP Server listening on port 8888
2012/02/26 01:29:40   579678 r reader tk initialized (device=/dev/sci0, detect=cd, mhz=357, cardmhz=357)
2012/02/26 01:29:41   579678 r tk card detected
2012/02/26 01:29:46   579678 r ERROR in IO_Serial_Read (errno=11 Resource temporarily unavailable)
2012/02/26 01:29:46   579678 r ATR: 3B 15 11 12 CA 07 15 CE
2012/02/26 01:29:47   579678 r Maximum frequency for this card is formally 5 Mhz, clocking it to 5.00 Mhz
2012/02/26 01:29:48   579678 r [dre-reader] illegal command: 5903E2E3FE9000.
2012/02/26 01:29:48   579678 r [dre-reader] type: DRE Crypt, caid: 4AE1, serial: C3A8D752, dre id: 325XXXXXXXXX, geocode 0, card: Platforma HD / DW old v4.2
2012/02/26 01:29:48   579678 r [dre-reader] Provider name:Tricolor_NC1.
2012/02/26 01:29:48   579678 r [dre-reader] SA = C3000000, UA = C3A8D752
2012/02/26 01:29:48   579678 r [dre-reader] no active packages
2012/02/26 01:29:48   579678 r [dre-reader] ready for requests
2012/02/26 01:29:48   579678 r found cardsystem dre
2012/02/26 01:29:49        0 s init for all local cards done
2012/02/26 01:29:49        0 s anti cascading disabled
2012/02/26 01:29:49   58E950 c plain dvbapi-client granted (root, au=on (1 reader))
2012/02/26 01:29:49   58E950 c dvbapi: 1 entries read from oscam.dvbapi
2012/02/26 01:29:49   58E950 c dvbapi: [ADD PID 0] CAID: 4AE1   ECM_PID: 0037   PROVID: 000002
2012/02/26 01:29:49   58E950 c dvbapi: [ADD PID 1] CAID: 4AE1   ECM_PID: 0028   PROVID: 000011
2012/02/26 01:29:49   58E950 c dvbapi: [ADD PID 2] CAID: 4AE0   ECM_PID: 0023   PROVID: 000000
2012/02/26 01:29:49   58E950 c dvbapi: [ADD PID 3] CAID: 4AE0   ECM_PID: 002E   PROVID: 000015
2012/02/26 01:29:49   58E950 c dvbapi: new program number: 697D (4AE1:697D unknown)
2012/02/26 01:29:50   579678 r [dre-reader] wrong signature: 5903E2ECF19000.
2012/02/26 01:29:50   58E950 c dvbapi: Start descrambling PID #3 (CAID: 4AE0) 1
2012/02/26 01:29:50   58E950 c root (4AE0&000015/697D/37:5B7A): not found (92 ms) by tk  - Perviy kanal
2012/02/26 01:29:56   58E950 c dvbapi: [ADD PID 0] CAID: 4AE1   ECM_PID: 002B   PROVID: 000002
2012/02/26 01:29:56   58E950 c dvbapi: [ADD PID 1] CAID: 4AE1   ECM_PID: 002C   PROVID: 000011
2012/02/26 01:29:56   58E950 c dvbapi: [ADD PID 2] CAID: 4AE0   ECM_PID: 0025   PROVID: 000000
2012/02/26 01:29:56   58E950 c dvbapi: [ADD PID 3] CAID: 4AE0   ECM_PID: 002F   PROVID: 000015
2012/02/26 01:29:56   58E950 c dvbapi: new program number: 0D54 (4AE1:0D54 unknown)
2012/02/26 01:29:56   579678 r [dre-reader] wrong signature: 5903E2ECF19000.
2012/02/26 01:29:56   58E950 c dvbapi: Start descrambling PID #3 (CAID: 4AE0) 1
 Я не спец, но насторожила следующая строка
« Последнее редактирование: 26 Февраль 2012, 18:05:40 от ooolexa »
Оффлайн XRunner
  • -> Вы поблагодарили: 17
  • Модель ресивера: Xtrend World Vision ET-9000
« Ответ #61 : 26 Февраль 2012, 03:16:15 »
Судя по логу у вас карта на 52, а 55 серии (их тоже вроде на замену 12 серии давали). Индент у вас, опять же судя по логу, 4AE1, а на 52 серии индент 4AE0. Какую сборку Вам лучше установить нужно спросить у ooolexa.
Либо сами распакуйте сборки 7ZIP b посмотрите, какая из них на Ваш индент настроена. Но в любом случае нужно будет заманить бинарник в usr\bin на мод от Юрика, тут: http://sat-forum.su/index.php/topic,8068.15.html
Остановите оскам и замените бинарник, предварительно переименовав его в oscam-experimental, не забудьте предоставить бинарнику права 755. Заработает, никуда не денется)))
ЗЫ отредактируйте своё сообщение и закройте крестиками эту строчку, вот так: dre id: 3255xxxxxxxx Незачем свой dre id всему интернету светить)
« Последнее редактирование: 26 Февраль 2012, 03:18:23 от XRunner »
Оффлайн killer130
« Ответ #62 : 26 Февраль 2012, 07:59:38 »
На карте написано, что она 52 серии... Не понимаю... :-[ :-[ :-[
В пункте -МЕНЮ-НАСТРОЙКА-SOFTCAM\CI-SOFTCAM SETUP-select softcam нет возможности выбора, в Card Server есть возможность выбрать на  - oscam-experimental
Если качать от Юрика, какой именно файл мне качать, там их несколько модификаций?
Еще вопрос - как тут уже у кого-то было написано, не могу создать папку tmp. Пробовал и через DCC, и через браузер, и переименовывать пробывал (при переименовании выдает ошибку 550)... не дает он создать там папку tmp. Вышел следующим путем создал папку temp, если нужно запустить ipk, в пути указываю свою папку. Может это еще как-то влияет???
« Последнее редактирование: 26 Февраль 2012, 08:23:13 от killer130 »
  • -> Вас поблагодарили: 14208
« Ответ #63 : 26 Февраль 2012, 14:18:46 »
killer130, зачем создавать папку /tmp она существует изначально в имидже ??????
Если у вас карта Триколор 52 серии то конечно следует устанавливать пакет конфигов e2-pli-et9000-ymodv18-t19_52karta_mipsel.ipk 3 поста этой темы , если до этого уже что то установили то команда в telnet будет
opkg install /tmp/e2-pli-et9000-ymodv18-t19_52karta_mipsel.ipk  --force-overwrite
естественно пакет должен уже находится в папке /tmp
Оффлайн killer130
« Ответ #64 : 26 Февраль 2012, 15:24:13 »
Уважаемый ooolexa изначально, после заливки имиджа папки tmp нет (у кого-то была такая же проблема на этом форуме), но вроде я решил эту проблему (удалил ярлык, куда все время кидалась папка tmp (там что-то вроде tmp -> /var/tmp) и удалось создать папку в корне.Оказывается это и была та самая папка.
ipk я устанавливал для 52 карты, как я уже писал - на карте стоит 52, по логу почему-то пишет 55
Вот в принципе сам лог, посмотрите пжл, может сразу станет видно где не так.
Ставил все, как писал XRunner для 52 карты, с заменой файлов и права755, но в меню Софткама (select softcam) так ничего и не появилось, в (kard server) стоит oscam-experimental. на дисплее горит значок карты
« Последнее редактирование: 26 Февраль 2012, 18:04:16 от ooolexa »
« Ответ #65 : 26 Февраль 2012, 15:59:12 »
killer130, ладно , смотрю вопрос не решается и вы меня не слышите . Задам вопрос Вам с фида open pli через меню плагины вы установили кардсервер oscam-experimental-cs (1.20-r0) ?????????????????????? >:(
Оффлайн killer130
« Ответ #66 : 26 Февраль 2012, 16:08:15 »
Прошу прощения за непонимание... ::)
Да ставил. Что я делал (по пунктам) -
1. установил новый имидж (PLI),
2. скачал с фида oscam-experimental-cs (1.20-r0)
3. ставлю libcrypto-compat_0.9.7-r2_all.ipk выдает ошибку
Collected errors:
 * opkg_install_pkg: Package libcrypto-compat md5sum mismatch. Either the opkg
r the package index are corrupt. Try 'opkg update'.
 * opkg_install_cmd: Cannot install package libcrypto-compat.
(пытался переустановить, все то же самое)
4. ставлю e2-pli-et9000-ymodv18-t19_52karta_mipsel.ipk
5. затем через DCC даю всем файлам оскама права 755
6. захожу в Softcam и только в Card servere меняю никакой на оскам-экспериментал. В softcame выбрать ничего не дает. Пепезагружается, на дисплее значок карты, каналы не идут
Оффлайн Puika
  • Модель ресивера: ET6000
« Ответ #67 : 26 Февраль 2012, 17:21:07 »
Collected errors:
Выше писали, перекачайте данный файл, это файл libcrypto-compat_0.9.7-r2_all.ipk скачался с ошибкой и система не может открыть этот пакет.
У вас файл битый...
Оффлайн killer130
« Ответ #68 : 26 Февраль 2012, 17:32:03 »
У вас файл битый...
Файл, который выложен здесь, качал несколько раз... Результат одинаковый...
Если есть у Вас нормальный, выложите здесь, пжл
« Ответ #69 : 26 Февраль 2012, 18:02:55 »
killer130, все забываем про libcrypto-compat_0.9.7-r2_all.ipk его ставить не обязательно если установили oscam-experimental-cs (1.20-r0) с фида openpli ,
Естественно и не будет не чего в softcame , Вы же установили  oscam-experimental-cs (1.20-r0) , а это кардсервер под карты условного доступа платных операторов спутникового телевидения. Нужен софткам , устанавливайте например mgcamd. В эмуляторе для софткама и кардсервера два пункта отдельно перезагрузки.
и логи эмулятора выкладывайте в файле .txt прикрепляя к сообщению , а то целые простыни висят ....
теперь стоит смотреть логирование карты , можете еще написать в icq 181039 будет быстрей.
« Последнее редактирование: 26 Февраль 2012, 18:16:39 от ooolexa »
Оффлайн killer130
« Ответ #70 : 26 Февраль 2012, 18:16:15 »
Естественно и не будет не чего в softcame , Вы же установили  oscam-experimental-cs (1.20-r0) , а это кардсервер под карты условного доступа платных операторов спутникового телевидения. Нужен софткам устанавливайте например mgcamd. В эмуляторе для софткама и кардсервера два пункта отдельно перезагрузки.
ooolexa Я не знаю, нужен совткам или нет. Мое желание смотреть 36 в полном объеме, а когда проблемы с и-нетом, чтобы спасала карта.
За "простыни" извините, не каждый день на форуме общаюсь...
Я так понимаю - мне теперь надо скачивать оскам +мгкам, и уже потом конфигурировать или можно отдельно мгкам поставить
(icq не пользовался, но сегодня постараюсь решить этот вопрос)
« Ответ #71 : 26 Февраль 2012, 18:21:56 »
killer130, Нет не надо mgcamd вам если будите пользовать карту + ш*ринг , с этой задачей прекрасно справляется oscam.
По поводу ш*аринга в oscam.cardserver под ридером карты есть еще два ридера (можно добавить сколько угодно под любой пакет) в которые можно прописать свои настройки доступа к серверу шары и после перезагрузки смотреть .
« Последнее редактирование: 26 Февраль 2012, 18:31:13 от ooolexa »
Оффлайн killer130
« Ответ #72 : 26 Февраль 2012, 19:20:23 »
ooolexa
Ш..ринг пока на втором месте, мне бы запустить карту...
Вот лог, со вставленной картой, и настройками для ш..ры, но увы пока тишина
УРА :)
отключил из ридера пункт про ш..ринг Радуги... пошла ш..ра
Остался единственный вопрос- запустить карту
« Последнее редактирование: 26 Февраль 2012, 19:33:54 от killer130 »
« Ответ #73 : 26 Февраль 2012, 19:33:32 »
killer130, ты на каком канале то стоишь для абдейта карты , в логе вообще канал из пакета нтв+.
Сейчас тоже попробовал запустить карту Xtra tv на et9000 долго что не хотела , потом взял отключил ридеры шаринга :
enable = 0 # 0 - ридер шары выключен ; 1  - ридер включен
и удалил на время файлы ключей : oscam.biss и oscam.keys и карта моментом активировалась и появилось изображение ......
так что как вариант проделать и тебе данный ход действий .
Оффлайн killer130
« Ответ #74 : 26 Февраль 2012, 19:36:31 »
как уже написал - отключил ридер ш..ры на радугу (enable = 0), удалил все файлы из tmp. Ш..ра пошла.
теперь осталось за картой...
УРАААААА
по каким-то причинам и пошла карта. в настройках не лазил, только поставил ридер на 0 для радуги
Спасибо большое всем за терпение!!!!!
Особенно ooolexa и XRunner
« Последнее редактирование: 26 Февраль 2012, 19:42:45 от killer130 »
