Всем привет!
Спасибо! Строку STARTUP удалось убрать unsetenv STARTUP
Напряжение батарейки в норме 3,17В при выключенном питании и проверке через сутки.
Подскажите, пожалуйста, куда дальше копать....просто дальше перебирать разные бутеры и имиджи? ниже привожу лог заливки и запуска openААF v1.0 от 2012 г:
RC2=00000015
BL=00000001
RC1=00000005
RC2=00000018
BL=00000002
RC1=00000005
RC2=00000018
BL=00000003
RC1=00000008
RC2=00000019
BL=00000004
RC1=00000004
RC2=00000015
BL=00000005
RC1=00000007
RC2=00000018
BL=00000006
RC1=00000003
RC2=00000019
BL=00000007
RC1=00000006
RC2=0000001A
SCfC3
COPY CODE
COMPARE CODE
4567
BCM97413B1 CFE v2.26, CFE core v2.12, Endian Mode: Little
Build Date: Sat Dec 10 11:20:16 WEST 2011 (Administrator@buildserver)
Copyright (C) Broadcom Corporation.
start cfe init device
sec-0 nblks=8 blksiz=8192
sec-1 nblks=63 blksiz=65536
Enabling NAND flash at CS1, NOR flash at CS0
NAND Flash size = 256MB
CPU speed: 405MHz
Memory Config: 64-bit UMA
Device Tech: 1Gb
Total memory: 512MB
Boot Device: NOR
Total flash: 4MB
Initializing USB.
USB: Locating Class 09 Vendor 0000 Product 0000: USB Hub
CFE initialized.
Set default GPIO...
USB: New device connected to bus 0 hub 1 port 2
USB: Resetting device on bus 0 port 2
USB: Locating Class 08 Vendor 1005 Product B113: Mass-Storage Device
USBMASS: Unit 0 connected
USB: New device connected to bus 1 hub 1 port 1
USB: Resetting device on bus 1 port 1
USB: Locating Class 09 Vendor 1A40 Product 0101: USB Hub
found image:
openaaf-1.0-20120109
flash image? (OK/CANCEL)
flashing...
Reading usbdisk0:et9x00/kernel.bin: Done. 3816616 bytes read
Programming...
offset=0 copysize=3816616
done. 3816616 bytes written
flashing...
Reading usbdisk0:et9x00/rootfs.bin: Done. 72220672 bytes read
offset: 00000000 size: 0FA00000
Force erasing...
Erasing flash...Erase address 0x35c0000 failed, bad block?
Programming...
offset=0 copysize=72220672
done. 72220672 bytes written
flashing completed!
booting...
Starting splash screen.
Loader:elf Filesys:raw Dev:nandflash0.kernel File: Options:(null)
Loading: !!!!! UNC read error occurred, while reading from NAND flash -1
0x80001000/7246144 0x806ea140/124464 Entry address is 0x8056cfc0
TP1 Entry Address at 0x80000ffc = 8056cfc0
Starting program at 0x8056cfc0
Linux version 3.1.0 (aaf-open@ks387398.kimsufi.com) (gcc version 4.4.4 (GCC) ) #
1 SMP Wed Jan 4 09:05:54 CET 2012
Fetching vars from bootloader... found 10 vars.
Early serial console at MMIO32 0x10400b00 (options '115200n8')
bootconsole [uart0] enabled
Options: sata=1 enet=1 emac_1=1 no_mdio=0 docsis=0 pci=1 smp=1 moca=0 usb=1
Using 512 MB + 0 MB RAM (from CFE)
bootconsole [early0] enabled
CPU revision is: 0002a044 (Brcm4380)
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
memory: 10000000 @ 20000000 (usable)
bmem: adding 216 MB RESERVED region at 40 MB (0x0d800000@0x02800000)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
Normal 0x00000000 -> 0x00030000
Movable zone start PFN for each node
early_node_map[2] active PFN ranges
0: 0x00000000 -> 0x00010000
0: 0x00020000 -> 0x00030000
PERCPU: Embedded 7 pages/cpu @81407000 s4416 r8192 d16064 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129536
Kernel command line: bmem=216M ubi.mtd=2 root=ubi0:rootfs rootfstype=ubifs rw co
nsole=ttyS0,115200n8
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Primary instruction cache 32kB, VIPT, 2-way, linesize 64 bytes.
Primary data cache 64kB, 4-way, VIPT, cache aliases, linesize 64 bytes
Memory: 291316k/524288k available (5603k kernel code, 232972k reserved, 1223k da
ta, 252k init, 0k highmem)
Hierarchical RCU implementation.
NR_IRQS:128
Detected MIPS clock frequency: 405 MHz (202.500 MHz counter)
Console: colour dummy device 80x25
Calibrating delay loop... 403.45 BogoMIPS (lpj=201728)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
SMP: CPU1 is running
Brought up 2 CPUs
NET: Registered protocol family 16
PCI2.3->SDRAM window: 512 MB
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
PCI: found device 14e4:8602 on SATA bus, slot 0 (irq 42)
pci 0000:01:00.0: BAR 5: assigned [mem 0x10510000-0x10510fff]
pci 0000:01:00.0: BAR 5: set to [mem 0x10510000-0x10510fff] (PCI address [0x1051
0000-0x10510fff])
pci 0000:01:00.0: BAR 6: assigned [mem 0x10511000-0x105117ff pref]
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource upg
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
fuse init (API version 7.17)
msgmni has been set to 568
io scheduler noop registered
io scheduler cfq registered (default)
fb0: bcmfb frame buffer device
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10400b00 (irq = 22) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10400b40 (irq = 66) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10400b80 (irq = 67) is a 16550A
loop: module loaded
brcm-pm: enabling sata clocks
PCI: Enabling device 0000:01:00.0 (0000 -> 0003)
scsi0 : sata_brcmstb
scsi1 : sata_brcmstb
ata1: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510000 irq 42
ata2: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510100 irq 42
Broadcom STB NAND controller (BrcmNand Controller)
bcmemac: Broadcom STB 10/100 EMAC driver v3.0
bcmemac: registered interface #0 at 0x10080000 as 'eth0' (00:16:b4:02:00:00)
bcmemac: not registering interface #1 at 0x10090000 (no PHY detected)
usbcore: registered new interface driver zd1201
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
brcm-pm: enabling usb clocks
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 62, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 57, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
ohci-brcm ohci-brcm.0: irq 63, io mem 0x10480400
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
ohci-brcm ohci-brcm.1: irq 64, io mem 0x10480600
ata1: SATA link down (SStatus 4 SControl 300)
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
lirc_dev: IR Remote Control driver registered, major 254
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR LIRC bridge handler initialized
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usb 1-2: new high-speed USB device number 2 using ehci-brcm
ALSA device list:
No soundcards found.
TCP cubic registered
NET: Registered protocol family 17
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
lib80211: common routines for IEEE802.11 drivers
EBI CS1: setting up NAND flash (primary)
mtd->oobsize=0, mtd->eccOobSize=0
NAND_CS_NAND_XOR=00000000
B4: NandSelect=50000200, nandConfig=16152300, chipSelect=1
brcmnand_read_id: CS1: dev_id=ecda1095
After: NandSelect=50000200, nandConfig=16152300
Block size=00020000, erase shift=17
NAND Config: Reg=16152300, chipSize=256 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
timing1 not adjusted: 5363444f
timing2 not adjusted: 00000fc6
eccLevel=15, 1Ksector=0, oob=16
nbrBitsPerCell=2, cellinfo=0, chip->cellinfo=00000000
<--brcmnand_set_acccontrol: acc b4: d7ff1010, after: d7ff1010
BrcmNAND mfg ec da Samsung K9F2G08U0A 256MB on CS1
Found NAND on CS1: ACC=d7ff1010, cfg=16152300, flashId=ecda1095, tim1=5363444f,
tim2=00000fc6
BrcmNAND version = 0x0302 256MB @00000000
Found NAND flash on Chip Select 1, chipSize=256MB, usable size=256MB, base=0
brcmnand_scan: B4 nand_select = 50000200
brcmnand_scan: After nand_select = 50000200
page_shift=11, bbt_erase_shift=17, chip_shift=28, phys_erase_shift=17
Brcm NAND controller version = 3.2 NAND flash size 256MB @10000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan: mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Bad block table Bbt0 not found for chip on CS1
Bad block table 1tbB not found for chip on CS1
Scanning device for bad blocks, options=00004000
scsi2 : usb-storage 1-2:1.0
ata2: SATA link down (SStatus 4 SControl 300)
usb 2-1: new high-speed USB device number 2 using ehci-brcm
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
Bad eraseblock 430 at 0x035c0000
scsi 2:0:0:0: Direct-Access USB FLASH DRIVE PMAP PQ: 0 ANSI: 0 CCS
sd 2:0:0:0: Attached scsi generic sg0 type 0
sd 2:0:0:0: [sda] 7831552 512-byte logical blocks: (4.00 GB/3.73 GiB)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] No Caching mode page present
sd 2:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 2:0:0:0: [sda] Attached SCSI removable disk
-->brcmnand_isbad_raw(offs=ffe0000
-->brcmnand_isbad_raw(offs=ffc0000
Adjust partition complete size from entire device to ff00000 to avoid overlap wi
th BBT reserved space
Adjust partition rootfs size from entire device to f900000 to avoid overlap with
BBT reserved space
Creating 3 MTD partitions on "brcmnand.0":
0x000000000000-0x00000ff00000 : "complete"
0x000000000000-0x000000600000 : "kernel"
0x000000600000-0x00000ff00000 : "rootfs"
UBI: attaching mtd2 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 0
UBI: volume 0 ("rootfs") re-sized from 549 to 1968 LEBs
UBI: attached mtd2 to ubi0
UBI: MTD device name: "rootfs"
UBI: MTD device size: 249 MiB
UBI: number of good PEBs: 1991
UBI: number of bad PEBs: 1
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 1991
UBI: number of PEBs reserved for bad PEB handling: 19
UBI: max/mean erase counter: 1/0
UBI: image sequence number: 1436159197
UBI: background thread "ubi_bgt0d" started, PID 43
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 248492032 bytes (242668 KiB, 236 MiB, 1957 LEBs)
UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:12.
Freeing unused kernel memory: 252k freed
INIT: version 2.86 booting
Root filesystem already rw, not remounting
Configuring update-modules.
usbcore: registered new interface driver tpm
modloader: module license 'PROPRIETARY' taints kernel.
Disabling lock debugging due to kernel taint
r8712u: module is from the staging directory, the quality is unknown, you have b
een warned.
een warned.
/etc/rcS.d/S21bootlogo: line 2: can't create /proc/stb/video/videomode: nonexist
ent directory
/dev/dvb/adapter0/video0: No such file or directory
cat: can't open '/proc/stb/info/boxtype': No such file or directory
ALSA: Restoring mixer settings...
Configuring dbus.
addgroup: group 'messagebus' in use
Adding system startup for /etc/init.d/dbus-1.
Configuring et-dvb-modules.
Configuring wpa-supplicant.
Configuring ntpdate.
adding crontab
Configuring libnss-mdns.
Configuring avahi-daemon.
addgroup: group 'avahi' in use
Adding system startup for /etc/init.d/avahi-daemon.
Configuring network interfaces... eth0 no wireless extensions.
udhcpc (v1.18.5) started
Sending discover...
Sending discover...
Sending discover...
No lease, forking to background
done.
modprobe: FATAL: Error inserting ipv6 (/lib/modules/3.1.0/kernel/net/ipv6/ipv6.k
o): Invalid argument
Starting portmap daemon: portmap.
Mounting remote filesystems...
vm.dirty_writeback_centisecs = 300
vm.dirty_background_ratio = 1
vm.dirty_ratio = 60
INIT: Entering runlevel: 3
Starting system message bus: dbus.
Creating Dropbear SSH server RSA host key.
Will output 1024 bit rsa secret key to '/etc/dropbear/dropbear_rsa_host_key'
Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgwCGi/ocfyV2Z5G16xBSiM2L2EsaDxh2VolwEKv+zyRE
4EswWKOXhKSGGSBF6y5uU5h9YPWMHJoL7lDGj1UsJmE3ikhpubHrRCb8BCEXuMbSN2hFbvRKvx+mwj4j
l2Wt5WSc+oE9MzHl7dKZtBAYWRWI9kVm5E4nXK5uagCSRH2PYUiT root@et9x00
Fingerprint: md5 17:51:4f:bd:0b:58:b9:fd:8f:22:5b:2d:d4:aa:71:98
Starting Dropbear SSH server: modprobe: FATAL: Error inserting ipv6 (/lib/module
s/3.1.0/kernel/net/ipv6/ipv6.ko): Invalid argument
dropbear.
starting Busybox Periodic Command Scheduler: crond... done.
crond[955]: crond: crond (busybox 1.18.5) started, log level 8
Starting internet superserver: inetd.
Starting syslogd/klogd: done
* starting FTP Server: vsftpd... done.
[ ok ]rting Avahi mDNS/DNS-SD Daemon: avahi-daemon
cat: can't open '/proc/stb/info/model': No such file or directory
PYTHONPATH: /usr/lib/enigma2/python
+ (1) Background File Eraser
+ (5) Tuxtxt
+ (8) graphics acceleration manager
BCM accel interface not available - Inappropriate ioctl for device
+ (9) GFBDC
812k video mem
FBIO_SET_MANUAL_BLIT: Inappropriate ioctl for device
FBIOPUT_VSCREENINFO: Invalid argument
fb failed
Segmentation fault
+ (5) Tuxtxt
+ (9) GFBDC
812k video mem
fb failed
Segmentation fault
+ (5) Tuxtxt
+ (9) GFBDC
812k video mem
fb failed
Segmentation fault
+ (5) Tuxtxt
+ (9) GFBDC
812k video mem
fb failed
Segmentation fault
+ (5) Tuxtxt
+ (9) GFBDC
812k video mem
fb failed
Segmentation fault
+ (5) Tuxtxt
+ (9) GFBDC
812k video mem
fb failed
Segmentation fault
+ (5) Tuxtxt
+ (9) GFBDC
812k video mem
fb failed
Segmentation fault
+ (5) Tuxtxt
+ (9) GFBDC
812k video mem
fb failed
Segmentation fault
+ (5) Tuxtxt
+ (9) GFBDC
812k video mem
fb failed
Segmentation fault
INIT: Id "gui" respawning too fast: disabled for 5 minutes
INIT: no more processes left in this runlevel
